* * * * * 1 votes
Does Your Gearbox Whine?
transmission lgt100
16 replies to this topic
#1 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted January 15, 2014 - 09:27 PM
The transmission in my closed side lgt100 whines like a teenager. especially in reverse.
Seems a bit loud to me.
it has a fresh load of gear oil, and the old oil didn't look bad.
#2 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted January 15, 2014 - 09:31 PM
I think a lot of the transmissions whine to some extent. Especially depending on the speed traveling and how much you hear it depends on the other ambient noises like exhaust noise level.
I think most of it has to do with how the gears are cut in the transmission.
  • IamSherwood and Chopperhed have said thanks
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted January 15, 2014 - 09:32 PM
The gears are getting tired.  Old farm tractors are especially bad about it.  Straight cut gears are the worst from what I was told, don't know if that is true or not.
Ben W.
#4 MH81 OFFLINE
Posted January 15, 2014 - 09:43 PM
Yes, some are louder than others. As long as it isn't bearing noise, no biggie IMO
  • Chopperhed said thank you
#5 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 15, 2014 - 09:46 PM
Ben W.
Yes, a lot of farm tractor restorers state that even thou the tractor is compleatly restored new gears are the only way to stop the whine.
  • superaben and Chopperhed have said thanks
#6 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 15, 2014 - 09:47 PM
I have several tractors, all sporting the same model tranny.
They all sound different. I use to worry about the noise they made, and
found that the more I thought about it, the worse it got.
  • Alc, trowel, pigsitter and 1 other said thanks
#7 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,227 Thanks
  • 1,083 posts
Posted January 15, 2014 - 10:02 PM
If memory serves me correctly straight cut gears are noisier than helical cut gears.My 214 & 216 have the same tranny and each has a sound of their own.
  • Alc, Chopperhed and Bill 76 have said thanks
#8 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted January 15, 2014 - 10:37 PM
I had a problem with the gearbox on my HB112 after I took it apart.  Took some videos of it.  Turned out I had something out of line when I put it back together.
http://gardentractor...-is-this-normal
  • Alc and Chopperhed have said thanks
#9 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted January 15, 2014 - 11:29 PM
I have really noticed it with old farm tractors. As long as they don't pop out I don't worry about it.
  • Alc, pigsitter and Chopperhed have said thanks
#10 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,309 Thanks
  • 4,948 posts
Posted January 16, 2014 - 12:23 AM
remove the muffler
:poke:   :rolling:  :wave:
  • IamSherwood, pigsitter, Chopperhed and 2 others have said thanks
#11 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted January 16, 2014 - 06:17 AM
Yep time for strait pipe
#12 KennyP ONLINE
  • 38,195 Thanks
  • 45,842 posts
Posted January 16, 2014 - 06:22 AM
My LGT 165 is quite loud too. But the FF's, with the same setup aren't near as noisy.
#13 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 16, 2014 - 06:48 AM
You should drive one of Doug's (DH1) electric tractors.
The tranny noise is so noticeable, you'd swear it's going to blow up under your butt. :smilewink:
Besides the birds chirping, there's nothing else to hear.
  • KennyP and Chopperhed have said thanks
#14 BTS ONLINE
BTS
    Make Stuff Up
  • 4,238 Thanks
  • 2,450 posts
Posted January 16, 2014 - 08:50 AM
I had a Allis Chalmers B, it had straight cut gears and it was the loudest thing you'd ever here. You had to have ear plugs just to run it!
#15 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted January 16, 2014 - 10:38 AM
I have that problem with my Jacobsens. I added Lucas oil oil stabilizer to the tranny and it helped a little noise wise but should help the gears last longer. It cost me like 10 bucks a quart at Advanced Auto Parts. I used around 25% oil stabilizer to save a little money but it says on the bottle that you can use up to 100%. I used the conventional type but they also have synthetic
Also tagged with one or more of these keywords: transmission, lgt100
