Automotive Power Steering Pump
10 replies to this topic
#1 Rickski OFFLINE
Rickski
  • 12 Thanks
  • 142 posts
Posted December 30, 2010 - 05:33 PM
Has anyone tried a automotive power steering pump on their GT to drive a hydraulic cylinder?
#2 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted December 30, 2010 - 05:42 PM
Not that i've heard but I've been thinking of the same thing, I think it's space issue with most gt's but not impossible.
#3 olcowhand ONLINE
  • 40,351 Thanks
  • 31,170 posts
Posted December 30, 2010 - 06:42 PM
Many have used them to power even a front end loader. The type on larger trucks are powerful & usually have a reservoir built on.
Here is one style that would work fine & easy to mount. This one is off an earlier Ford, like 70's 289/302/351 Windsor.
http://www.borgeson....hp?type=C&id=86
#4 TUDOR OFFLINE
TUDOR
  • 544 Thanks
  • 497 posts
Posted December 30, 2010 - 07:45 PM
I used a GM pump and cylinder from a '60s Chev for a front blade lift over 30 years ago. The GM pumps put out about 2 gpm at up to 1450 psi., but can be modified for more flow with relative ease. Get one that comes with a remote reservoir, then change the reservoir to meet your requirements. I understand that Dodge and Fisher plows have been using them for quite a few years now.
Finding the fitting to adapt the pressure line to regular hydraulic fittings is a chore, but they are out there.
Bob
#5 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted December 30, 2010 - 08:41 PM
I am going to move this thread to the garden tractor forum instead of site questions :D
#6 olcowhand ONLINE
  • 40,351 Thanks
  • 31,170 posts
Posted December 30, 2010 - 09:07 PM
I didn't even notice where the post was. I'd better improve on modding or my pay might be cut! :smilewink:
#7 MH81 OFFLINE
Posted December 30, 2010 - 09:09 PM
Glad someone was awake, thanks George!:D
#8 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,868 Thanks
  • 1,850 posts
Posted December 30, 2010 - 09:39 PM
I have a Toro Groundsmaster with a 88 inch front deck on it.
About 5-years ago, the hydraulic pump on the front of the hydro transmission went bad so I adapted a power steering pump off a 78 Chevy on to the engine.
there is a hydraulic tank up on the radiator with a hose that fastens on to the top of the power steering pump.
This is where I fill the pump from and it gives the pump extra fluid capacity.
The pump operates three cylinders. One for lifting the whole deck and two for raising and lowering the outside wings on the desk.
#9 Tinkerer OFFLINE
Tinkerer
  • 18 Thanks
  • 200 posts
Posted December 30, 2010 - 10:21 PM
I am considering using a Fisher snow plow pump with the snowplow valve controller to run some hydraulics on my 1220. I already have these just need to make a mount to mount it to the 1220.
#10 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted December 30, 2010 - 10:49 PM
I wouldn't worry about it we all do it. :D
#11 mjodrey OFFLINE
Posted December 31, 2010 - 05:48 AM
Yes I have,I used one to power a snow plow on one of my trucks a few years ago,If I remember it was a Saginaw pump off of a G.M. car from the '70s.It didn't work too bad,mind you it was just to lift the blade and power angle.
