For Sale
Sears St10 Engine
No replies to this topic
#1 farmerall OFFLINE
farmerall
  • 2,204 Thanks
  • 1,474 posts
Posted January 13, 2014 - 11:54 PM
Up for sale is an engine that I pulled out of a Sears St10 tractor. The tractor it came out of was built by Murray so this is a 10hp Briggs and Stratton vertical shaft engine. I have been told this engine particular engine is hard to find due to it having a special crankshaft in which part of the crank is smaller in diameter and it also needs a drive pulley. I have not pulled the drive/pto pulley off to confirm or deny this. Hopefully some one with more experience with these tractors can let me know. Now on to the engine, I have never heard it run. It does turn over with compression but does not have spark. This should be a simple fix by just swapping in a newer magneto instead of messing with the points ignition. I have no use for this engine and it is just sitting in my shed taking up space.
I'm located near Pittsburgh Pa
Asking 40 obo, the engine is complete with the carb and starter.
Sorry for the bad picture, I will try to find a better one and post it soon.
