Allis/simplicity Large Frames With Duals, Who Have Pics?
11 replies to this topic
#1 victor3ranger OFFLINE
victor3ranger
  • 315 Thanks
  • 630 posts
Posted January 13, 2014 - 04:06 PM
Who all has a Allis or Simplicity that is running duals and how are they mounted?
I have seen somewhere the ring spacer that goes between the wheels but what do you guys think?? Is that a pretty solid setup for running duals?
  • hamman said thank you
#2 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted January 13, 2014 - 04:29 PM
I had the rings for a few years...still have them, and I'd let them go.  I came across OEM and aftermarket spacers, which I use for show now.  I'll have to dig for more detailed pics of the actual spacers.  Been a while.
Aftermarket (xtrememotorworks)...8.5" Deestones inside of 6-12 Carlisle TruPowers
OEM...6-12 Schenuit's inside of 6-12 Carlisle TruPowers
  • hamman and trowel have said thanks
  • 14,815 Thanks
  • 15,502 posts
Posted January 13, 2014 - 04:53 PM
Early on when we farmed, the rings and turn buckle set up was all there was for most farm tractor. Later on the manufacturer's started supplying longer axles to mount a second set of hubs on, you could use a second full rim and tire. All of our tractor had ring and clamp duals and we never had any problems with them.
  • trowel said thank you
#4 littlemarv OFFLINE
littlemarv
  • 61 Thanks
  • 61 posts
Posted January 13, 2014 - 05:44 PM
I made these,
with inspiration from here:
http://www.xtrememot...s/CC-01-001.htm
#5 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted January 13, 2014 - 06:31 PM
My old allis had duals. No spacers just bolted together. It actually worked well.uploadfromtaptalk1389655855351.jpg uploadfromtaptalk1389655869456.jpg
#6 KC9KAS OFFLINE
KC9KAS
  • 5,389 Thanks
  • 4,692 posts
Posted January 13, 2014 - 06:43 PM
Try something like these...........
#7 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 13, 2014 - 07:29 PM
Off the net, can't quite tell what the spacer is.
#8 Texas Deere and Horse OFFLINE
  • 14,815 Thanks
  • 15,502 posts
Posted January 13, 2014 - 11:27 PM
Jess, Those are the square spacers in your photo above.
#9 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 14, 2014 - 07:56 AM
Thanks, good eyes.
#10 victor3ranger OFFLINE
victor3ranger
  • 315 Thanks
  • 630 posts
Posted January 14, 2014 - 10:06 AM
I am wondering what all adapters will fit with the long axle stub that sticks thru the center of the wheel.
I am sure the square ones pictured above and the ring type will work but are there others? My 716 and 916 both have 23x10.5x12 tires, are these too big to run duals?
Edited by victor3ranger, January 14, 2014 - 10:07 AM.
#11 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted January 14, 2014 - 10:32 PM
What is the objective for setting them up? I dont even care to run the 6" tires as duals...I wouldnt run 8.5' and especially not wider. Uneven ground of any sort when running duals can snap an axle tube easily. I only set them up for show, as they were offered by the manufacturer, for certain applications. I like the Carlisle 6-12's as they are a half inch shorter than my other tires and dont even touch the ground when on a flat surface.
#12 victor3ranger OFFLINE
victor3ranger
  • 315 Thanks
  • 630 posts
Posted January 16, 2014 - 09:45 AM
My thinking on this is for use in loose blow sand.  My little wheel horse I am going to put duals on it just because but it only uses the 6x12's.
The rest of my GT's all use 23x10.5x12's, if I did do this I would only do it to one GT that would be running around in the sand. But, the more I think about it, it might be a better idea to just get a set of 26x12x12 floataion tires. Not sure those would even fit though.
