Hubs Problem
10 replies to this topic
#1 Kevin Vasich OFFLINE
Kevin Vasich
  • 87 Thanks
  • 174 posts
Posted January 12, 2014 - 08:09 PM
Hey How can I grease the seal inside the clutches? Are the hubs suppose to look like the picture?
#2 Kevin Vasich OFFLINE
Kevin Vasich
  • 87 Thanks
  • 174 posts
Posted January 13, 2014 - 08:21 PM
Any Help PLEASE
#3 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted January 13, 2014 - 08:56 PM
My hubs do not look like that. Do both of them look like that? Do you have a manual?  If not, google gravely manuals and you will see a site with free manuals.
  • Texas Deere and Horse and Kevin Vasich have said thanks
#4 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted January 13, 2014 - 10:10 PM
The hub has had the keyway "buggered" up. Thats the technical term :D. I have read about what you are seeing as being a common problem with those types of hubs. I only have a L8 so I am not familiar with your problem and how to fix it. I think I read that you can replace the hub or have a new keyway braoched in. The other tractor site has a big gravely group that can give you specifics on the repair.
  • Kevin Vasich and michael.kitko have said thanks
#5 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted January 13, 2014 - 10:18 PM
I was gonna advise having a new keyway broached...
Sent from my CAT B15 smartphone.
  • Kevin Vasich said thank you
#6 Kevin Vasich ONLINE
Kevin Vasich
  • 87 Thanks
  • 174 posts
Posted January 14, 2014 - 08:23 PM
Thanks guy I think I got fix today.
#7 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted January 14, 2014 - 10:59 PM
Good for you..     What no pictures?
#8 Kevin Vasich OFFLINE
Kevin Vasich
  • 87 Thanks
  • 174 posts
Posted January 16, 2014 - 06:21 PM
Here some picture drove it around today. Looking for a sleeve hitch for it now. Plan to plow with it in April hope to came to Pa plow day this year.
  • olcowhand said thank you
#9 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted January 17, 2014 - 07:10 PM
I see you done some work on the 812. Did you get a new muffler or did you paint it? Different rear wheels & tires, engine cleaned and all spiffed up. New plug, & points? New fuel filter and fuel line?  You put the deck on, I see the deck is the newer style. Shes coming along good. Its good to see someone breath new life into a good older tractor.  Good work Kevin
#10 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted January 17, 2014 - 07:12 PM
I forgot about the clutches and hubs, Does she out good and smooth now?
#11 Kevin Vasich OFFLINE
Kevin Vasich
  • 87 Thanks
  • 174 posts
Posted January 21, 2014 - 11:03 AM
The hubs are tight now. The clutches are good got to two more if needed but have to rebuild them first.
