Briggs Id
12 replies to this topic
#1 Brando OFFLINE
Brando
  • 338 Thanks
  • 331 posts
Posted January 11, 2014 - 07:38 AM
Go to look at this Briggs this afternoon, I'm limited on knowledge on these older Briggs but the fella says its a 1946 7hp. I'm think its possibly a model a or z which makes it from 1-4hp from what I've read but again I don't know.Unfortunately I don't have the numbers off of it. I have always wanted and older briggs engine.
Edited by NCtractorman83, January 11, 2014 - 08:18 AM.
  • hamman and boyscout862 have said thanks
#2 DougT ONLINE
DougT
    Dog Approved
  • 6,281 Thanks
  • 4,564 posts
Posted January 11, 2014 - 08:07 AM
I would say its either a Z or a ZZ. On a Z, the carb inlet will be 3/4". On a ZZ, it will be 1". I think the ZZ was rated up to 6HP. An A doesn't have the removable output plate.
  • powerking56, hamman, trowel and 2 others have said thanks
#3 trowel OFFLINE
trowel
    Summer.
  • 4,820 Thanks
  • 4,533 posts
Posted January 11, 2014 - 08:12 AM
I would grab it if the price is right, looks very good.
  • hamman and Brando have said thanks
#4 Brando OFFLINE
Brando
  • 338 Thanks
  • 331 posts
Posted January 11, 2014 - 08:23 AM
Thanks for the info DougT, Those little details like that is what I don't know to point me in the right direction. I have been searching this morning I found a video of 47 ZZ and it looks a lot like the one im wanting to buy.  Im not exactly sure what you mean by removable output plate?
http://www.youtube.c...h?v=MwjQOsMX7HY
#5 DougT ONLINE
DougT
    Dog Approved
  • 6,281 Thanks
  • 4,564 posts
Posted January 11, 2014 - 08:31 AM
In your last pic of the pulley and compressor you can see 3 of the 4 bolts that hold it where the crank comes through. If you look at an A from that side, the block is cast solid. There isn't a removable piece there. I think the Z/ZZ was the only ones to change to a tin shroud too.
  • Brando said thank you
#6 Brando OFFLINE
Brando
  • 338 Thanks
  • 331 posts
Posted January 11, 2014 - 08:39 AM
Fella said it runs good and comes with air compressor.
  • trowel said thank you
#7 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted January 11, 2014 - 08:45 AM
Looks good, the published hp rating is low, but believe me they have plenty of "snot", I run my saw rig with a 1947 Z.
#8 Brando OFFLINE
Brando
  • 338 Thanks
  • 331 posts
Posted January 11, 2014 - 08:46 AM
Ahh ok, Much appreciated. I think this is my favorite part is learning about it.
#9 Brando OFFLINE
Brando
  • 338 Thanks
  • 331 posts
Posted January 11, 2014 - 08:48 AM
Im thinking of putting this on a old roto hoe tiller im restoring for something different.
#10 trowel OFFLINE
trowel
    Summer.
  • 4,820 Thanks
  • 4,533 posts
Already set up to be rebuilt, cleaned and painted for shows, very nice.
#11 trowel OFFLINE
trowel
    Summer.
  • 4,820 Thanks
  • 4,533 posts
Posted January 11, 2014 - 08:49 AM
Ah, cool, posted just as you did, would be plenty for that thumper.
#12 Brando OFFLINE
Brando
  • 338 Thanks
  • 331 posts
Posted January 11, 2014 - 10:55 AM
That's what im thinking.
#13 Brando OFFLINE
Brando
  • 338 Thanks
  • 331 posts
Posted January 12, 2014 - 08:55 AM
Here it is got home late last night, its a 1946 ZZ  7hp from what he the fella said and I found on a few websites, not 100% sure on the hp part I read that the ZZ ranges from 6.2 to 7.7 hp. It started first pull no smoke ran great will be perfect for my tiller resto project.
