Springs
5 replies to this topic
#1 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted January 11, 2014 - 05:30 AM
Does anyone know of a good supplier for springs? I have couple good hardware stores here but I can't find just the right length and tension/compression rate for my use. They will be for my David Bradley walk behinds. I have a couple originals to go by.
Thanks
#2 MH81 OFFLINE
Posted January 11, 2014 - 06:04 AM
Are these extension or compression?
The place won't help (out of business) but the one time we needed something that had to be "exact" dad and I went and they measured it. Diameter of wire, pounds to extend 1", etc. I found this place http://www.diamondwi...om/catalog.aspx that has a branch in Taylors SC.
  • IamSherwood, VSTROM803 and superaben have said thanks
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted January 11, 2014 - 08:25 AM
McMaster Carr has springs. I've measured and bought some governor springs to replace sold NOS parts before from them.
Ben W.
  • MH81, Alc and VSTROM803 have said thanks
#4 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 11, 2014 - 08:57 AM
Thanks
What part/application are the springs for ?
#5 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted January 12, 2014 - 05:33 AM
They are for a David Bradley walk behind reverse. One is for the mechanism on the trans-axle, the other is for the control rod on the handlebar.
#6 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 12, 2014 - 03:28 PM
have had good luck with local hardware store spring modify the ends for the clutch spring.
Reverse use Snapper spring.
