Time to enter Tractor of the Month!
What's The Model?
15 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,322 Thanks
  • 1,770 posts
Posted January 10, 2014 - 08:53 PM
Anyone know anything about this? It's small but has a big rear end. I've never seen a s/g on a vertical shaft engine. Anything over good or overly bad about these?
Sent from my SAMSUNG-SGH-I437P using Tapatalk
  • Alc and hamman have said thanks
#2 wku88 OFFLINE
wku88
  • 22 Thanks
  • 35 posts
Posted January 10, 2014 - 08:59 PM
I don't know anything about the tractor, but if that is a 650 or 750 Homelite, You need to grab it.
  • hamman said thank you
#3 boyscout862 ONLINE
  • 10,763 Thanks
  • 8,068 posts
Looks like an AC Homesteader LT. Same as the Simplicity Broadmoor. Usually 8 hp. Articulates in the center, which is often seized. If seized, can be major job to free up. Good Luck, Rick
  • hamman and OkieGt have said thanks
#4 JDBrian OFFLINE
  • 9,594 Thanks
Posted January 10, 2014 - 09:01 PM
A small Allis with a big rear end! No comment!!
  • hamman and trowel have said thanks
#5 BairleaFarm OFFLINE
BairleaFarm
  • 1,322 Thanks
  • 1,770 posts
Posted January 10, 2014 - 09:07 PM
I don't think it articulates (scratches head) wku..talking about the tiller?
#6 Texas Deere and Horse OFFLINE
  • 14,472 Thanks
  • 15,392 posts
Posted January 10, 2014 - 09:46 PM
It articulates right in front of the gear shift, were the big break in the frame is. The front axle is rigid mounted to the frame.
  • hamman, BairleaFarm and boyscout862 have said thanks
#7 BairleaFarm OFFLINE
BairleaFarm
  • 1,322 Thanks
  • 1,770 posts
Posted January 10, 2014 - 09:59 PM
Hmmm, now I almost have to have it just for the challenge.
#8 trowel OFFLINE
trowel
    Summer.
  • 4,820 Thanks
  • 4,533 posts
Posted January 10, 2014 - 10:01 PM
My uncle had the simplicity one of this, forget the model no/name, solid little tractor.
You should get it.
Edited by trowel, January 10, 2014 - 10:01 PM.
  • hamman and BairleaFarm have said thanks
#9 ckjakline OFFLINE
ckjakline
  • 1,120 Thanks
  • 1,116 posts
Posted January 10, 2014 - 10:04 PM
I have a yellow allis b-209 that looks just like that only a different color.
#10 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,678 Thanks
  • 1,348 posts
Posted January 10, 2014 - 10:34 PM
What he's saying is it twists in the middle and not on top of the front axle.
Not trying to step on your toes Brian
#11 pharmer OFFLINE
pharmer
  • 764 Thanks
  • 715 posts
Posted January 11, 2014 - 08:35 AM
Regular steering. See the rod coming out the side and spindles in the front axle ?
#12 TAHOE OFFLINE
TAHOE
  • 7,086 Thanks
  • 5,254 posts
Posted January 11, 2014 - 08:51 AM
Sure looks like an AC B207  painted Simplicity orange
http://simpletractor..._&_pleasure.htm
It also loks like the 208, but the vertical engines was only in the 207. The 208 went horizontal.
Edited by TAHOE, January 11, 2014 - 08:57 AM.
  • trowel said thank you
#13 trowel OFFLINE
trowel
    Summer.
  • 4,820 Thanks
  • 4,533 posts
Posted January 11, 2014 - 08:54 AM
Use a jack and jack up one side of the tractor, see how it twists in front of the gear stick.
#14 Canawler OFFLINE
Canawler
  • 1,913 Thanks
  • 1,771 posts
Posted January 11, 2014 - 11:56 AM
The hood bump makes it pre-Homesteader, either a repainted 207 or a 208.  The 207s were yellow and I believe all the 208s were orange (I'm sure someone will confirm or correct.)  All of the small frame tractors used vertical engines right up through the 5010 Simplicity and the 610 Allis in the late '70s.
Edited by Canawler, January 11, 2014 - 11:58 AM.
#15 Talntedmrgreen OFFLINE
  • 3,151 Thanks
  • 2,230 posts
Posted January 11, 2014 - 02:52 PM
It is an early B-207 or B-208...both were yellow, both had vertical shaft engines, and both had the hood scoop and wider rear tires.  Identical machines, except for the engine.  Homesteaders came later, and there were even B-207 and B-208 models in orange and cream, with no hood scoop, between the Yellow varieties, and the Homesteaders of the 70's.  There was also a yellow B model or two with no hood scoop.  Some had 'E' designations for 'electric start', and there was even a B-208 'Super' variety.
They seem fairly scarce, modly because the limited offering seems to have been hacked up between a variety of only slightly different models.
These tractors did not articulate, but pivoted in the center, to keep all 4 tires and the mower deck on the ground.  There was never a B-209 model.
They differed from Simplicity cousins, in that they used a Peerless transaxle, instead of the SImplicity built transaxle found in all others.  Due to this difference, they do not take Simplicity rear attachments such as a tiller or revitalizer, as they have no rear PTO.
