Who Sells Good 3 Pin Cub Cadet Clutches
10 replies to this topic
#1 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted January 09, 2014 - 10:35 PM
which is good for pulling
#2 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted January 09, 2014 - 11:48 PM
Stock would probably be fine.
#3 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted January 10, 2014 - 12:18 AM
http://www.midwestsupercub.net/
  • Dieselcubmike said thank you
#4 Grumpy OFFLINE
Grumpy
  • 710 Thanks
  • 612 posts
Posted January 10, 2014 - 07:41 AM
I make an aluminum clutch disc. work well in stock altered.
#5 TommyWilliamson OFFLINE
TommyWilliamson
  • 5 Thanks
  • 11 posts
Posted February 05, 2014 - 03:52 PM
These people have so much stuff for pulling. Some of it is well worth it.
#6 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted February 05, 2014 - 08:50 PM
clutch wont matter if you dont have a spring behind it.
#7 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted February 06, 2014 - 04:35 PM
All depends on what the engine is. A 8hp stock or a 120hp twin don't need the same clutch.
For the stocks we used 3-396 chevy outer valve springs over the stock spring; Never had any problems in the stock classes
#8 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted February 06, 2014 - 08:29 PM
iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
That guy knows, we have a guy running a metal 3 puck clutch, and it slips and sparks after a few pulls, 14hp told him he needs a spring.I like the 396 springs.
#9 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted February 09, 2014 - 09:43 PM
go with Midwest super cub good guys to deal with too.
#10 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 18, 2014 - 07:16 PM
Kerber machine has stuff to and he's cheaper
#11 Rbrracing32 OFFLINE
Rbrracing32
  • 16 Thanks
  • 56 posts
Posted February 19, 2014 - 10:22 AM
What do you put at the ends of the springs a big washer to keep them from going over the collets or roll pins which ever you use.
