For Sale
Wisconsin Tra10D Parts
12 replies to this topic
#1 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted January 09, 2014 - 10:22 PM
I have some parts that I saved from a TRA10D engine that I got on a parts Bolens 1050. I never heard this engine run but all of the parts look tike they are still useable or will cleanup ok. I have a crank, rod and piston, camshaft, governor and flywheel. The crank has some marks on the rod journal but nothing bad if I remember right.
#2 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted January 10, 2014 - 04:14 AM
Is it a std size piston or oversized?
#3 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted January 10, 2014 - 09:39 AM
I think it's a std size but I will check to make sure.
  • Nato77 said thank you
#4 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted January 14, 2014 - 04:18 PM
My brother checked for me today and he said that 1/2 is stamped into the top of the piston. I have no clue what that number means though, I'm used to seeing std, .10 .20 ect.
#5 Bolens 1000 ONLINE
  • 14,908 Thanks
  • 18,109 posts
Posted January 14, 2014 - 04:27 PM
Those are Bored 1/2 over  (.05)
Instead of throwing out defective blocks the factory would bore them slightly oversize and install a special Size piston and rings.
#6 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted January 14, 2014 - 05:55 PM
Guys!   :mad2:
....Get your decimals in the right place! :poke:
There's a huge difference between .10" and .010"   :wallbanging:
The 1/2 marking would represent .005" not .050"
.10 = 1/10    .010 = 10/1000 or 1/100  :thumbs:
  • Bolens 1000, Texas Deere and Horse and farmerall have said thanks
#7 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted January 14, 2014 - 08:35 PM
So what size rings would you use? .010 and file them down to fit?
#8 Bolens 1000 ONLINE
  • 14,908 Thanks
  • 18,109 posts
Posted January 14, 2014 - 11:25 PM
Yes, .010 Would be your only Choice
I had to do that on the engine in my EK10.
I didnt have to file mine as the ring gap was within specs.
I dont think the 1/2 over sizes were ever stocked by any dealers......
  • farmerall and Nato77 have said thanks
#9 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted January 14, 2014 - 11:40 PM
Do you think it being 1/2 over add any value to the piston or most likely it would be a cool conversation piece?
#10 Bolens 1000 ONLINE
  • 14,908 Thanks
  • 18,109 posts
Posted January 15, 2014 - 10:59 AM
If you think they are "Rare" they are not...... Likely thousands were sent out of the factory like that.
To me its just another Ordinary Engine
#11 wilberj ONLINE
wilberj
  • 4,990 Thanks
  • 5,589 posts
Posted January 15, 2014 - 04:22 PM
Your talking .005 here thats .0025 per side nothing realy.
#12 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,835 Thanks
  • 2,330 posts
Posted January 17, 2014 - 06:37 PM
Do you have the carb and gov springs?
#13 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted January 17, 2014 - 07:09 PM
I may have a carb, I'll have to look. I don't have any of the governor springs.
