If I Burned Wood I Would Love This!
12 replies to this topic
#1 jdslednut OFFLINE
jdslednut
  • 679 Thanks
  • 851 posts
Posted January 09, 2014 - 01:18 AM
Not sure if this has been posted before but this thing is the boss!
  • Gtractor, MH81, hamman and 8 others have said thanks
#2 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted January 09, 2014 - 01:58 AM
Must being using to much gas to heat the house lately to be looking at alternative heating sources.
Maybe you should get one so I can borrow it on the weekends :D
  • hamman and JRJ have said thanks
#3 KC9KAS OFFLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted January 09, 2014 - 05:05 AM
I have watched this video before. Very neat, but my comment was, "You mean it doesn't stack the wood too"?
#4 jms180 ONLINE
jms180
  • 1,616 Thanks
  • 1,617 posts
Posted January 09, 2014 - 08:24 AM
looks like the driver eats a lot of saw dust. It is a nice operation.
  • hamman, New.Canadian.DB.Owner and JRJ have said thanks
#5 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted January 09, 2014 - 08:40 AM
Yes, looked like a neat operation, 3-in-1 deal.
#6 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 10,479 Thanks
  • 6,175 posts
Posted January 09, 2014 - 09:53 AM
This is posted somewhere else before.
There are better alternatives for wood processors.  That one is pretty cool, but I went to a yard that sold fire wood.
They had a setup that had a conveyor belt on it.  You laid a log down, up to 10' it pulled it in, cut it, split, and ran it up a conveyor belt to dump on a pile.  Worked awesome.  I watched it for about 10 minutes and it was puking out wood non stop.  14" cut, split into 8 pieces, feed, 14" cut, split into 8 pieces,  Non stop wood coming down.
#7 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted January 09, 2014 - 11:19 AM
Yes I think I have seen that posted on here before. It is a neat setup!! You would have to process a lot of wood to justify the expense.
#8 Cvans ONLINE
  • 7,056 Thanks
  • 6,283 posts
Posted January 09, 2014 - 01:11 PM
The only problem I see is none of the trees around here grow anywhere near as straight as those trees.
  • IamSherwood said thank you
#9 shorty ONLINE
shorty
  • 5,758 Thanks
  • 5,380 posts
Posted January 09, 2014 - 06:10 PM
That is some neat engineering. It doesn't look quite as fast as a stationary setup. But then the startup cost would be lower.
  • toomanytoys84 said thank you
#10 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 10,479 Thanks
  • 6,175 posts
Posted January 09, 2014 - 06:17 PM
Figure in the cost of a skid that has enough hydraulic power to run it you might as well buy a stationary machine. But then a skid steer has many many uses
  • shorty said thank you
#11 shorty ONLINE
shorty
  • 5,758 Thanks
  • 5,380 posts
Posted January 09, 2014 - 06:18 PM
Yeah. I was thinking of it as if you already had a skiddy to use.
#12 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted January 09, 2014 - 06:39 PM
I looked into those.. its not a simple quick attach set up. if i recall it was 38000 bucks. a statonary set up is 20 with a lot of toys on it.. not worth the money at all...
  • IamSherwood and shorty have said thanks
#13 IamSherwood OFFLINE
  • 8,395 Thanks
Posted January 09, 2014 - 07:11 PM
Yes, and that problem applies to any processor I've ever seen. Good straight trees, are usually
worth more as saw logs, so the cull wood gets thrown aside for firewood.
  • Cvans said thank you
