Opps, Broke A Crankshaft
15 replies to this topic
#1 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted January 08, 2014 - 08:38 PM
Today I was trying to pop the flywheel off a 14 Kohler and broke it. I was using a hammer and a couple screwdrivers like I have done many times before and the end of the crank snapped off. Well I guess I have another engine to add to the collection under the workbench.
Edited by farmerall, January 08, 2014 - 09:24 PM.
  • Texas Deere and Horse, superspeedex and Oldford have said thanks
#2 IamSherwood OFFLINE
  • 8,390 Thanks
Posted January 08, 2014 - 08:58 PM
Opps
  • farmerall said thank you
#3 MH81 OFFLINE
Posted January 08, 2014 - 09:01 PM
Hmm, never seen one do that. Must've been either a very off-sides hit or previously weakened and you just finished it off.
Sorry about your luck.
#4 js5020 ONLINE
js5020
  • 654 Thanks
  • 766 posts
Posted January 08, 2014 - 09:02 PM
BUMMER
#5 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
CRAP !
#6 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted January 08, 2014 - 09:09 PM
My guess is all of the above. I'm not to worried about it, we will just have to find another engine for my brothers Cub Cadet project.
#7 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted January 08, 2014 - 09:12 PM
I've heard of people putting the crank in a lathe , machining the end flat where it broke , drilling and tapping the end of the crank and installing a bolt with the cupped washer .
Just a thought .
Heres a thread on what I'm talking about ...
http://www.cubcadetc...ken crank#p6300
Edited by Jlaws, January 08, 2014 - 09:22 PM.
  • MH81, Texas Deere and Horse, farmerall and 1 other said thanks
#8 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted January 08, 2014 - 09:14 PM
A good machine shop could fix ya up
#9 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted January 08, 2014 - 09:15 PM
I've heard of people putting the crank in a lathe , machining the end flat where it broke , drilling and tapping the end of the crank and installing a bolt .
Just a thought .
Thanks for the suggestion, I will keep that in mind. We were planning on swapping the flywheel and bearing plate with one from a K301 so the engine would fit in my brothers 104. We will either fix this one or find another some day.
#10 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted January 08, 2014 - 09:29 PM
That was me :wallbanging:  Did the exact same thing you did. Only cost $30 to repair. Engine is still going as far as I know.
  • Jlaws said thank you
#11 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted January 08, 2014 - 09:37 PM
Hey Levi , small world isn't it .  I've never done it myself , but if the crank is in good shape otherwise , I wouldn't hesitate doing it .
#12 Texas Deere and Horse ONLINE
  • 14,730 Thanks
  • 15,470 posts
Posted January 08, 2014 - 09:41 PM
Matt, Sorry to hear that, I would use the above way described to repair and fix the crank..
#13 Justin2655 OFFLINE
Justin2655
  • 204 Thanks
  • 148 posts
Posted January 08, 2014 - 10:17 PM
I work in a repair machine shop and yes you can fix the crank. Is what we do is face it off, drill a hole, cut a new peice of round stock, stub that peice ( V out both the crank and the new peice of stock) and slide them together (slip fit). Then weld them together and machine down to size
#14 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,129 posts
Posted January 09, 2014 - 03:57 AM
You should invest in a steering wheel puller.They work great for pulling fly wheels.They are right around $30 at sears.
#15 olcowhand OFFLINE
  • 40,340 Thanks
  • 31,169 posts
Posted January 09, 2014 - 10:04 AM
Mt Lincoln Weldanpower with a K241 did the same, but I was using a puller.  I taper ground the threaded portion & welded it back on with nickel rod.  Still on 0ver 10 years later.  But would be best maybe for you to drill & tap for a 7/16 fine thread bolt.
