Peerless 2300 Series Transaxle
8 replies to this topic
#1 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted January 08, 2014 - 08:22 PM
Ok i while back i posted a thread on this i i forget who but i m pretty sure someone on here can get me parts for my speedex rear end im probaly going to need a few gears and bearings and seals so if anyone can tell me where to get the parts please do.  Thanks for and help!!!
#2 farmerall OFFLINE
farmerall
  • 2,217 Thanks
  • 1,482 posts
Posted January 08, 2014 - 08:40 PM
I still have that one from the JD if you want a complete trans.
  • superspeedex said thank you
#3 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted January 08, 2014 - 08:57 PM
yea i know i need to come get that too.  dont worrie i didnt forget about it
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 08, 2014 - 09:51 PM
I have Peerless parts.  What do you need?
Ben W.
#5 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted January 08, 2014 - 09:56 PM
i not sure yet i just need to know where i can get parts if i tear it apart.  its jumps outta 3rd and 4th gear
#6 lyall OFFLINE
lyall
  • 2,250 Thanks
  • 1,602 posts
Posted January 08, 2014 - 11:18 PM
if you is jumping out of gear - you need to replace the spring and ball on the shifting forks
you should replace the both springs and ball in each shifting forks
you can get the springs and balls from Deere
the last time I got them the springs are around $3.00 each and the ball about the same price
if you need any gears let me know - I have several gears available I can send you
#7 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted January 09, 2014 - 06:18 AM
Yea ok 4th gea it will barely go in like it dont even click but 3rd i can run a little bit then it will pop out i know its been jumping outta 4th for a couple years now but it has really gotten bad this year.  the input shaft theres a bearing and seal i am going to need them too.  And one last question does anyone know how much oil it holds?
#8 lyall OFFLINE
lyall
  • 2,250 Thanks
  • 1,602 posts
Posted January 09, 2014 - 07:18 PM
If I remember right it should around 2 quarts
most use 85w-90 and some use the 85w-140
the ones that use the 85w-140 say it rans quieter, but is you are in areas that stay below freezing for long periods of time I would use the 85w-90
the manual for the peerless is in the manual section on this site
there three manuals there that will help you a lot
Tecumseh Technican's Handbook Tecumseh/Peerless 2300 Series Parts List Tecumseh/Peerless 2300 Transmission Repair
#9 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted January 09, 2014 - 09:38 PM
Ok thanks im going to the john deere dealer tomorrow see if they got anything then im probably gonna pull it apart and fix it ill keep you updated p[probably make a build thread
