Sickle Bar Mower
13 replies to this topic
#1 Jsx485 OFFLINE
Jsx485
  • 2 Thanks
  • 8 posts
Posted January 06, 2014 - 09:31 PM
I have 4 acres and a creek runs through it. I need to trim both sides of creek, but often the grass is too soft for john deere x485 to mow next to water. Also the land along the creek in most places is not manicured enough to let my tractor get close enough to mow. I thought a sickle mower would be a great idea, but new ones are wasaay out of my budget. Any thoughts on sickle mower, an older one that would work on my tractor.
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted January 06, 2014 - 09:50 PM
Sickle bar mowers are loosing their popularity due to the so called safety hazards.  Like a farmer friend once said, idiots loose toenails around them.
Your best bet is a used one.  Just make sure it is a major brand that still supports parts.  Ford/Dearborn mowers are good choices, for example, because mower sections and belts are very universal.
How about a Jari self propelled sickle bar mower?  It is fresh on my mind because I am trying to get rid of one.  They are light and stick like a burr on a hill.
Ben W.
  • IamSherwood said thank you
#3 MH81 OFFLINE
Posted January 06, 2014 - 09:59 PM
You will probably have to find the right thing to make it bolt up. Possibly use a horse drawn unit? Wouldn't be sexy and it'd take a second person,
#4 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted January 07, 2014 - 02:03 AM
Finding a sickle bar mower now days is as good as trying to win the lottery. Slim chance.
Been looking for one to fit one of my cubs, found one but would of had to give up my first born, and he didn't feel like moving :say_what:
As mention if you could find a ground driven style, you'd be in business.
#5 Alc ONLINE
  • 6,885 Thanks
  • 7,460 posts
Posted January 07, 2014 - 06:51 AM
My son is going to have the same problem cutting around his pond , I tried to modfiy a DB but you still can't get close enough to the water , I was thinking a wheeled string trimmer modifed to cut 90* might work .
http://gardentractor...-db-sickle-bar/
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted January 07, 2014 - 09:19 AM
I have a simular situation. I have a large Grain Elevator with thousands of square feer of concrete draining on my propery.
Making about 1/2 acre of marsh and a waterway across the property.
I too had considered a sickle bar mower but my tractor is heavy enough I am afraid it would go down in the mud.
I'm thinking one of the self powered mowers that could be pulled behind an AtV or mower where you can swing the tongue off to the side might be the best answer? Something like this. 31818_200x200.jpg
#7 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted January 07, 2014 - 12:56 PM
Severial years ago I built up an old sears tractor with a sickle mower mounted on the side.
I used to mow a steep bank along the road and around a small pond.
I could cut the weeds right down into the water.  It worked really good !!
  • trowel and Cvans have said thanks
#8 Jsx485 OFFLINE
Jsx485
  • 2 Thanks
  • 8 posts
Posted January 07, 2014 - 05:10 PM
2-Bladeup.jpgNice job. That looks great!
#9 Jsx485 OFFLINE
Jsx485
  • 2 Thanks
  • 8 posts
Posted January 07, 2014 - 10:28 PM
Nice job, that looks great!
#10 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted January 07, 2014 - 10:53 PM
I never thought to ask this, do you have a 3 point hitch and a rear 540 pto on your X485?
#11 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted January 08, 2014 - 10:02 AM
Hi,
A point to consider: I have a 1967 Economy Power King with a mid mount sickle bar.
Its problem is the down angle is limited to horizontal/flat. So to mow down a bank side is impossible.
I know most other sickle bar mowers are not limited in this manner. Just wanted to mention it.
Good Luck.
Chuck
#12 js5020 OFFLINE
js5020
  • 684 Thanks
  • 787 posts
Posted January 08, 2014 - 10:16 AM
One of the many reasons I keep a Gravely walk behind around,, sickles can be had in 40" and 60" wide, although the 60"s are difficult to find, they are out there. Yes parts are still available but not cheap.
#13 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted January 08, 2014 - 11:52 AM
  • js5020 said thank you
#14 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted January 09, 2014 - 09:51 AM
Man, I would love to have a side sickle mower for my Allis B-110, I think those are really cool.
I see someone mentioned a old horse drawn type, has anyone here ever used one of those as a pull behind for your GT??
I MAY know where one of those are located, but I would have to dig the silly thing out from under the sand, its mostly buried now.
