Cub Cadet 3 Blade 42 Inch Cut
4 replies to this topic
#1 618jeff OFFLINE
618jeff
  • 70 Thanks
  • 46 posts
Posted January 06, 2014 - 06:09 PM
Anyone tell me why my deck on both my 122 and 127 cuts high in the center.  the 127 has new blade set . also under the deck the 3 curve pieces has been fixed , I'm at a lose , any help
thanks jeff
#2 Grumpy OFFLINE
Grumpy
  • 748 Thanks
  • 624 posts
Posted January 06, 2014 - 06:42 PM
Have you checked the deck level front to back? If it is high in front it will cut higher in the middle.
Grumpy
#3 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted January 07, 2014 - 11:53 PM
Have you checked that you have the center shaft in the spindles the same?
Got same amount of washers between the blade and spindle? Maybe there is no washer, don't know for sure.
#4 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted February 11, 2014 - 08:23 PM
A few years ago I had the same issue and low and behold there was a washer under the center but no washer on the 2 smaller blades ........ it took me about 2 weeks of thinking and looking till I figured that out
#5 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted February 25, 2014 - 01:19 AM
I guess he figured it out.
