Need ideas for a rear tube frame wieght box build!
17 replies to this topic
#1 fonz3482 OFFLINE
fonz3482
  • 1913 Thanks
  • 890 posts
Posted December 28, 2010 - 07:40 AM
Has anyone built a wieght box for the rear of there tube frame? If so do you have the dimensions, wieght, etc., etc. Also some pics would help! I have a few ideas but I just would like to see a known good setup before I start building. I made up a bracket last year but the steel was weak, and I used my workout wieghts. Well my wieghts are starting to rust so I dont want to use them again and ruin them. Thanks everyone!! I appreciate the help!!!
#2 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted December 28, 2010 - 08:04 AM
Maybe this will give you some ideas. In the diagram you can see the mounting points.
  • mjodrey and MH81 have said thanks
#3 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted December 28, 2010 - 08:06 AM
What do you need the extra weight for?
#4 fonz3482 OFFLINE
fonz3482
  • 1913 Thanks
  • 890 posts
Posted December 28, 2010 - 08:13 AM
I need the wieght for snowblowing. The tractor is ok without it but the tires do spin at times. I had the same issue last year and made up a temporary wieght bracket. I know theres better ways to add wieght but Im strapped for cash right now. I have alot of steel so I figured I'd make a wieght box. Has anyone one tried to make a wieght for the belly of the tractor? like where the deck would mount? Some wieght in the middle of the tractor might help me steer better with the blower down.
#5 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted December 28, 2010 - 08:21 AM
Shouldn't be too hard, but watch how far down it hangs. Easy enough to get hung up in the snow without stuff hanging down. :D
#6 tractormike OFFLINE
tractormike
  • 179 Thanks
  • 1488 posts
Posted December 28, 2010 - 09:02 AM
You could always go the windshield washer fluid route on the rear tires. A 23x8.50x12 rear tire should hold 6 gallons easy enough and that would add about 40 pounds per tire. I have caught the windshield washer fluid on sale for .99 a gallon.
#7 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 6034 Thanks
  • 2244 posts
Posted December 28, 2010 - 09:16 AM
Has anyone one tried to make a weight for the belly of the tractor?
I put an underbelly weight system on a tractor that I built.
The weights are made out of 5-sections of 2x3 steel tube that are filled with lead.
This adds 280 pounds to the tractor.
I made up an angle iron frame to hold them.
This frame is fastened under the rear axle.
The weights are slid in from the back.
There is a steel plate that bolts on the back for the 3-point hitch and that keeps the weights in place.
  • caseguy and Reverend Blair have said thanks
#8 fonz3482 OFFLINE
fonz3482
  • 1913 Thanks
  • 890 posts
Posted December 28, 2010 - 09:40 AM
Thats kinda what im thinking of doing. I got 4" angle iron for tracks, I wanna attach them to the underside of the tractor by where the deck would mount. Then slide in 1/2" steel plates for wieght. I currently have 4- 1/8" plates. There 16"x16" and wieght 35lbs. If I use @ 6 to 8 pieces of 1/2" plate, plus the wieght of the bracket should bring me up to @ 100lbs. Last year I had @ 75lbs of dumbell wieghts strapped to the back. It worked good, but steering was poor. So Im hopefully mounting the wieght in the middle will help front and rear traction issues.
#9 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted December 28, 2010 - 10:43 AM
I'd fill the tires too. I'm a big believer in filling tires and adding wheel weights, since it keeps the weight on the ground without weighing down the axle. Didn't somebody on here adapt some barbell weights to be wheel weights?
That's a nice weight system, JDCrawler. It's neat, out of the way, and easily adjustable if you need some weight but don't want all of it.
#10 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted December 28, 2010 - 04:48 PM
I think your best and easiest option would be to fill the tires with windshield fluid.
#11 Rednecklawnmower OFFLINE
Rednecklawnmower
  • 1 Thanks
  • 24 posts
Posted December 28, 2010 - 11:51 PM
il put them tire chains on my 1050 and then my fat ass will keep it in traction lol
#12 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted December 29, 2010 - 05:52 AM
lol
#13 fonz3482 OFFLINE
fonz3482
  • 1913 Thanks
  • 890 posts
Posted December 29, 2010 - 07:27 AM
ok, so I did some measuring last night and the belly wieght system would be nice but its gonna be alot of work. I have a fully packed garage, no heat, and Im strapped for time soooooo im gonna haft to stick to a rear wieght box or filling tires. Someone mentioned washer fluid? I dont have tire tubes, and just sandblasted and repainted my rear wheels. Will the washer fluid rust my wheels out? Also whats the fastest way to fill them? How much would I need, with 25x10x12 tires? How much wieght will this add?
Edited by fonz3482, December 29, 2010 - 07:36 AM.
#14 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted December 29, 2010 - 08:11 AM
Answers in order:
Rust? No, it'll be fine, never heard of this being a problem.
Fastest? Lay them on their side, Break down one side & start pouring
Weight? Mike mentioned above that your size tire otta hold about 40# each
Hope that's enough, good luck
#15 Rednecklawnmower OFFLINE
Rednecklawnmower
  • 1 Thanks
  • 24 posts
Posted December 29, 2010 - 09:55 AM
Put antifreeze in them too maybe just an idea. We also had water in them rear tires in 460 IH farmall and i dont see any problems with them.
