Sold
Massey Ferguson Mf620 Snowblower 35 Tooth Drum Sprocket
massey ferguson mf620 snowblower snow thrower sprocket
14 replies to this topic
#1 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted January 05, 2014 - 08:48 PM
Looking for the 35 tooth drum sprocket on a Massey Ferguson MF620 snow blower. It is the newer style blower. I finally got around to mounting mine on my MF12 and went to try it out and it sounded horrible. Found it was skipping teeth so I took the drum out. My sprocket is in really bad shape. Looks like it has been getting chewed for a long time before I even bought it. If anyone has one they can part with let me know.
#2 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted January 05, 2014 - 09:10 PM
George I may have what you need I parted out a MF blower many of the parts look almost new so I pulled it apart do you have any pics, I think I keep the tag off of this one so maybe we can cross it over
                Kenny
  • NUTNDUN said thank you
#3 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted January 05, 2014 - 09:12 PM
Thanks Kenny.
I don't have a pic of the sprocket right now but it is the only one on the unit that is 35 teeth and it has about 6 bolt holes in it to attach it to the drive side of the drum.
#4 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted January 05, 2014 - 09:47 PM
I looked in the manuals and I don't see a blower made like the one I parted I am sure it was made buy Haban the mounts and arms looked a lot like the ones used on a  Haban flail even the helper spring it had was made the same I will look tomorrow and get you a model number I'm sure I saved it
#5 TAHOE ONLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted January 06, 2014 - 08:59 AM
Hey George, look at this thread. It is for an Old Sears/Craftsman blower, but he had a 35 tooth/6 bolt sprocket he needed to replace,found one at TSC and modified.  Maybe some useful info for yours.
www.mytractorforum.com/showthread.php?t=426506
  • NUTNDUN and MH81 have said thanks
#6 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted January 06, 2014 - 10:21 AM
I found one just like he found at tractor supply at surplus center and would need to drill the mounting holes. I am going to swing by TSC on the way home from work today to see if I can find the same one that he used. One extra tooth would actually help in my case since it seems like my chain is way too long.
#7 Walkinman1 OFFLINE
Walkinman1
  • 767 Thanks
  • 583 posts
Posted January 06, 2014 - 11:40 AM
If the chain seems too long and the sprocket is worn out I'd replace the chain as well cuz they wear/stretch. A worn chain will skip on a new sprocket and tear it up in a hurry...
  • NUTNDUN and Texas Deere and Horse have said thanks
#8 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted January 06, 2014 - 08:01 PM
I got a new sprocket for the snow blower. I was going to order the sprocket I seen on surplus supply as it was the same tooth count but after reading the link Tahoe posted and finding out that TSC had basically the same sprocket except one extra tooth I stopped on the way home today.
I thought for sure it would have taken me longer to drill all the mounting holes in the new sprocket but it didn't take long at all. I also picked up 10 foot of new #40 chain. I clamped the new sprocket to the old one with the center hole centered as best as possible and used my transfer punches to transfer the center of the mounting holes. Removed the clamps and used my punch to mark the centers even more and drilled in three incremental sizes. I had to use the die grinder to remove some material from the center hole to fit on the shaft.
Got everything bolted up with new chain in place and adjusted correctly. Took it out to test it and she is blowing snow better than ever. Skimmed the snow right down to the grass too :D
Sprocket: http://www.tractorsu...6t-hub-series-x
  • MH81, Texas Deere and Horse and Cvans have said thanks
#9 MH81 OFFLINE
Posted January 06, 2014 - 09:17 PM
Pics? Video?
#10 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted January 06, 2014 - 09:47 PM
Hey that's a good deal George at least your up and running
#11 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted January 07, 2014 - 08:23 AM
Pics? Video?
Sorry no pics or video. I really need to get better with taking pics while working on something as it would make for better threads. It wouldn't take long to pop the drum back off the snow blower to get pics so I may do that.
#12 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted January 07, 2014 - 08:40 AM
Do we need points here?
  • MH81 and Cat385B have said thanks
#13 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted January 07, 2014 - 10:39 AM
I think so. May even be deserving of a 3 day ban LOL.
#14 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted January 07, 2014 - 10:48 AM
Wouldn't that technically be a vacation? Just make with the pic posting, chop-chop. Sir.
#15 MH81 OFFLINE
Posted January 07, 2014 - 01:27 PM
Isn't that your average week? :poke:
Also tagged with one or more of these keywords: sold, massey, ferguson, mf620, snowblower, snow thrower, sprocket
