1946 David And Bradley Walk Behind Tractor Value
value
16 replies to this topic
#16 rut3556 OFFLINE
rut3556
  • 8 Thanks
  • 31 posts
Posted February 01, 2014 - 08:46 AM
Is it me or do those wheels appears to be later ones than the "original" model? Oh, and I see you're from Kalispell...... great little town!
#17 DougT ONLINE
DougT
    Dog Approved
  • 6,855 Thanks
  • 4,953 posts
Posted February 01, 2014 - 01:37 PM
Does Any One Know How Adjust The Governor? I Lost The Metal Link That Goes From The Carb To The Governor So I Need To Know The Length Of This Link So I Can Make A New One. Any Help Would Be Greatly Appreciated. Thank You
 With the engine off, move the throttle to the wide open position. Move the gov lever in the same direction until it bottoms on the gov. The distance between the two points will be what you need. Spring pressure should try to make the throttle go wide open and the gov should work to shut it.
Also tagged with one or more of these keywords: value
