Help Me Figure Briggs Throttle Problem
3 replies to this topic
#1 glgrumpy ONLINE
  • 8,707 Thanks
  • 7,972 posts
Posted January 04, 2014 - 02:48 PM
Have tractor with Briggs 16 engine and the Flow-jet carb. I've rebuilt the carb last summer. Think I really have a governor problem. With cable hooked up, all moves fine with it. The gov arm out of the block barely  moves when setting still. I tried setting with BS instructions from manual. First I had it racing, then got back to idling OK. Barely moves tho when setting?  There is a long rod that you can set the gov speed with that goes to bracket on top. I played with that some so get nice sounding top speed. The thing is the throttle lever/cable moves same each time, YET the throttle never stays same. I can start the engine fine in idle. Sometimes when I throttle up it is running just as it should. Other times I throttle up and theres NO action. If I leave the lever up and drive some, then it starts to creep up some, and used to be racing pretty hard till I set the top gov speed on that link I mentioned. Can govs get sticky or worn inside block and cause issues?  I don't really know what is inside for gov controls, never had one down that far. OR, is there just too much slop in my throttle shaft? didn't seem to be when I cleaned it up, but ???  There are two springs on the linkage which seem way sloppy most times, yet when I try diff holes and such, either get nothing in speed up or blasting full throttle. I have them in positions now that look like correct according to the BS Book. Maybe some new springs is really all I need?  I'm at a loss with these engines. Give me a Kohler any day for ease of maintainance.
  • hamman said thank you
#2 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,554 Thanks
  • 2,898 posts
Posted January 04, 2014 - 03:29 PM
Can you post a picture of the throtle linkage? I have a Briggs 16hp in a Homelite I can get a picture of for you if you need. My BIL has a Simplicity 7014 that had a problem with nearly the same thing. The throttle cable had been hooked up wrong. When he changed it it works perfectly. Roger.
  • HDWildBill said thank you
#3 New.Canadian.DB.Owner OFFLINE
  • 2,347 Thanks
  • 1,502 posts
Posted January 04, 2014 - 03:37 PM
There was another fellow asking a similar question a couple of days ago.  Check this out.  It might help.
http://gardentractor...5-carb-linkage/
  • sacsr and HDWildBill have said thanks
#4 TAHOE ONLINE
TAHOE
  • 8,166 Thanks
  • 5,759 posts
Posted January 06, 2014 - 08:50 AM
Since your having problems, shoot me your address, I will be up and take it off your hands for ya :bigrofl:
I can't help ya, I do have an old Briggs manual, but haven't had to adjust a governor. I have replaced one in a motor though do a rod breaking and taking out internal parts.
