Blowing Snow But Not Real Well!
13 replies to this topic
#1 metrodoggreg OFFLINE
metrodoggreg
  • 67 Thanks
  • 89 posts
Posted January 03, 2014 - 07:57 PM
It doesn't seem to blow real well like it's running backwards is that possible? It kick more forward then out chute.
  • JDBrian and MyBolens1053 have said thanks
#2 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted January 03, 2014 - 08:03 PM
I dont see how you could run it backwards.  Looks from how much snow is there it needs to be fed more.   Whats that 2/3inch? Blade would work better if thats all it is.
  • MyBolens1053 said thank you
#3 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 03, 2014 - 08:05 PM
:ditto:
Looks like you just have enough to clog the chute :D
Single Stage blowers need to be fed A high volume of snow for them to throw the snow far.
I usually use the Blower in 3''+ of snow. Anything less gets the blade
  • wilberj and MyBolens1053 have said thanks
#4 metrodoggreg OFFLINE
metrodoggreg
  • 67 Thanks
  • 89 posts
Posted January 03, 2014 - 08:20 PM
Ok I see.That explains it. Thanks!
#5 metrodoggreg OFFLINE
metrodoggreg
  • 67 Thanks
  • 89 posts
Posted January 03, 2014 - 08:30 PM
The guy I bought it from. Had some wanna be small engine repair guy working on it. I have spent most of my time working on it correcting everything he touched! He had fuel screw out over 3 turns! Starter was loose. Tank mount spacers not installed laying on starter. He wrecked 2 brush springs and pulled wires out of 2 brushes on starter. Only thing he was supposed to do is fix tranny which had a broken bracket which needed welding. All fixed runs very well but have to change oil because of previous carb settings.
  • OkieGt and MyBolens1053 have said thanks
#6 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted January 03, 2014 - 08:54 PM
These Bolens whip snow around so hard the chute can't contain it all.
Nice cab ya got there, btw.
#7 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted January 03, 2014 - 08:55 PM
Yep, what those guys already said.
I don't have a whole lot of experience with mine yet, but the less snow you've got, the faster across the ground you want to go. The first storm, we got about 7" and I was mostly using second gear in low range. This week, we got 3-4"' and I was using first and second in high range.
It seemed to me that it worked best when I was feeding the snow in as fast as possible without bogging the blower down and causing a drop in rpm. I have pretty much used all 6 speeds depending on snow depth.
Bob
#8 OkieGt OFFLINE
OkieGt
  • 1434 Thanks
  • 1447 posts
Posted January 03, 2014 - 09:09 PM
I always say, If some idiot is going to work on my tractor, it might as well be me
  • boyscout862 and Oregon_Bolens have said thanks
#9 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 03, 2014 - 09:15 PM
It takes a bit of getting used to but after a while you will get the hang of it.
Like mentioned above, matching ground speed to the type and amount of snow is key.
Here's a video to show you what they can do :D
  • JDBrian, marlboro180, Oregon_Bolens and 2 others have said thanks
#10 metrodoggreg OFFLINE
metrodoggreg
  • 67 Thanks
  • 89 posts
Posted January 04, 2014 - 05:53 AM
Ok that helps first time I've had it out. My wife even likes it.
#11 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted January 04, 2014 - 07:35 AM
Thanks for the video. I have a single stage 49 blower that i am rebuilding for use on a JD314 or 317. I have never used a single stage blower so these tips are useful.
#12 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 04, 2014 - 07:43 AM
As said, there isn't enough there to make the thrower work.
Bummer eh. You thought you might get some seat time. :D
#13 Walkinman1 OFFLINE
Walkinman1
  • 773 Thanks
  • 599 posts
Posted January 04, 2014 - 08:04 AM
Metrodog, I've used a single stage in snow like you have in your picture and it works, but it's not ideal. My Sears single stage seems to be better across the board than the H42 blower on my cub which definitely prefers deep snow. The biggest thing is adjusting your speed. As has already been suggested, the less snow you have the faster you need to go (which isn't always practical) so a blade or two stage blower are better choices for small snowfalls. One technique I've used in confined areas where I can't get enough speed to keep the blower full is to shut off the PTO and CAREFULLY use the blower like a box blade to push the snow into a more accessible area, then ramp up my ground speed to throw it out of the way.
  • IamSherwood and MyBolens1053 have said thanks
#14 metrodoggreg OFFLINE
metrodoggreg
  • 67 Thanks
  • 89 posts
Posted January 04, 2014 - 08:10 AM
I will change my technique makes sense. Sure is fun and cab keeps me warm.
