Wanted
Wanted- Tube Frame Handle Parts
tube frame blower shoot handle
4 replies to this topic
#1 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted January 03, 2014 - 11:42 AM
looking for a part for my bolens tube frame blower...The lower part of the handle that the worm gear is connected to
    I don't know if you can still buy them NEW ??
#2 boyscout862 OFFLINE
  • 13,693 Thanks
  • 9,476 posts
Posted January 03, 2014 - 12:55 PM
Try our sponsors. Good Luck, Rick
#3 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted January 05, 2014 - 07:10 PM
Can you find a pic of what you need? I may have them.
#4 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 4,008 Thanks
  • 2,485 posts
Posted January 06, 2014 - 04:19 PM
There were at least 3 different pinion shafts used on tube-frame sno-casters.
Part # 1714639 has a straight shaft at the top which fits into a u-joint.  ....There is a roll pin hole at each end.  ....This shaft firt the yellow model 18514 (32") and yellow model 18516 (36") attachments.
Part # 1722580 has a "hook end" at the top, which fits into a rectangular swivel block.  ...This shaft was used on the 38" models 18538-01, -02, -03.
Part # 1734779 has a "hook end" at the top, which fits into a rectangular swivel block.  ...This shaft was used on the 38" model
18538-04 attachment.
I do not know what is different between the last two parts.
Do you know which model sno-caster you have?  ....What color is it?
  • Bolens 1000 and sodisr have said thanks
#5 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted January 19, 2014 - 02:01 PM
Bruce,,,   Sorry for the delay....  It is a black snowcaster..
  probably one of the last 2 you mentioned
              18538   01   02    03
               18538     04
    Yes it's got the hook and the rectangle swivel  block to join the upper and lower pcs.
  I think I will take it appart and get it welded..  Cheap place to start..
        Thanks      sodi
Also tagged with one or more of these keywords: Wanted, tube frame blower, shoot handle
