* * * * * 1 votes
"super Garden Tractors"
52 replies to this topic
#1 scuffy727 OFFLINE
scuffy727
  • 131 Thanks
  • 92 posts
Posted January 02, 2014 - 11:51 PM
I know cub cadet coined this phrase when they introduced the 982, but I also like to consider other garden tractors of similar size as a super garden tractor.  Mainly when I refer to a garden tractor as a SGT it needs to be shaft driven and an engine size of 16hp and up.  The frame needs to be heavy of course and the tires usually are: Front tire:            18x8.50-8 and the Rear tire:  26x12.00-12.  I know that they are tons of different models out there, and with that said I put together a little comparison of some SGT that were competing with each other for their share of the market.  Some of the information is incomplete so feel freely to add any information that is missing. Most of the information and pictures came from the internet, I thought it would be interesting to put it all together in one spot.
  • MH81, Texas Deere and Horse, hamman and 5 others have said thanks
#2 boyscout862 ONLINE
  • 12,833 Thanks
  • 9,160 posts
Posted January 03, 2014 - 03:34 AM
Add Ford LGT 195, PK, AC 616, BH JBII, and Case 646. Good Luck, Rick
  • hamman and Dieselcubmike have said thanks
#3 KennyP ONLINE
  • 38,267 Thanks
  • 45,876 posts
Posted January 03, 2014 - 06:40 AM
Sears also had the FF18 & FF24. I'm sure there are others that can be added to that.
  • hamman said thank you
#4 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted January 03, 2014 - 06:58 AM
Would a PK with 24 inch rear wheels fit in? Might be more towards farm tractor then even a super garden tractor. You could add a 1618 to the list though! I will PM you later with specs.
  • hamman, KennyP and Bill 76 have said thanks
#5 grnspot110 ONLINE
grnspot110
  • 4,148 Thanks
  • 2,641 posts
Posted January 03, 2014 - 07:09 AM
My '83-420 would fall into that category, not much smaller than my '04-790 CUT:
  • hamman and KennyP have said thanks
#6 Talntedmrgreen ONLINE
  • 3,273 Thanks
  • 2,306 posts
Posted January 03, 2014 - 08:48 AM
I think of my Legacy (though a bit of a later model) as a SGT.  They market the current XL model oddly, as a "Subcompact Garden Tractor" (wouldn't that mean, smaller than a 'Garden Tractor'??), but I don't feel it stacks up to the implied SCUT badge.
It is, however, an amazingly strong perfomring 'Super' garden tractor, IMO.  Fits your criteria to a 'T'.  Like the JD mentioned above, it offered optional 3pt and PTO, had a diesel model available, standard power steering and diff lock, auxillary hydraulics, hangs in there with a 55" wheelbase, tips the scales at right around 1000# (depends on engine and options).  It will handle a wide variety of proprietary and CAT0 or Limited CAT1 attachments.  But, it is simply is not beefy enough to properly operate larger Cat1 attachments, work with more than 600# in the bucket, 450# on the 3pt, or power hydraulic motor implements.  I have a 60" flail mower I play with, and while it will do it, it is clear it only wants to play for a little while.  I wouldn't want to be asking SCUT performance of that tractor....it does stand a head above my beefiest Garden Tractor though.
Edited by Talntedmrgreen, January 03, 2014 - 09:05 AM.
  • hamman, KennyP and OkieGt have said thanks
#7 twostep ONLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted January 03, 2014 - 08:55 AM
It looks like this list is of the "first" SGT's from each of the big producers... otherwise you would yave to include the other JD 4xx's, the other Cub "Supers", the other WH D-series, etc.
  • hamman and Talntedmrgreen have said thanks
#8 TAHOE ONLINE
TAHOE
  • 7,964 Thanks
  • 5,672 posts
Posted January 03, 2014 - 08:58 AM
Of course you got the MF 1655/1855's :smilewink:
I was thinking there was a small tractor labeled Kubota with a diesel in it that could be considered a SGT, don't know model number.
Along with the simplicity is the PowerMax, but I think it was a true SGT and I think Allis had like the green 1920 or something like that
#9 Talntedmrgreen ONLINE
  • 3,273 Thanks
  • 2,306 posts
Posted January 03, 2014 - 09:09 AM
The Sunstar line (AGCO, Deutz, Massey included) is a great example as well.  I don't have the specs on those, but they fall in line, for sure!
From a standpoint of stature, the Powermax line certainly borders on SCUT territory...they are a much larger, heavier tractor, especially when considering the era they were built:
Simplicity 9020
Engine: 19.5 hp [14.5 kW]
Wheelbase: 56 inches [142 cm] Weight: 1,300 lbs [589 kg] Front tire: 20x8.00-10 Rear tire: 29x12.00-15
#10 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,311 Thanks
  • 4,948 posts
Posted January 03, 2014 - 09:19 AM
SGT.....
is that "sub garden tractor"?
  • jimbobbillyray and twostep have said thanks
#11 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted January 03, 2014 - 09:20 AM
There is a lot of gray area, that has came into the classifiacation over the years.
Many of the original Gt's and their specs fall into todays category of SCUT (Sub Compact Tractors).
Of the original Super GT's I always think of the  International & JD 400 series.
Some of the early machines fell into a range I would consider early efforts to create a SCUT.
SCUT was a term that did not exist at the time and the manufatureres classified them as Compact Utiiitys.
If you really wanted to muddy the waters I guess you could throw the Cub lowboys,184.185's into that range?
I would throw the Ford 195 Wheel Horse, D250, Allis Chalmers 620 & 720 etc into that class as well.
Talntedmrgreen  Simplicity rates the Legacy as a SCUT. They are a very good and capable machine in that category. Though I think it is a bit on the  light side of the category they do offer a loader and Backhoe for it, and it can operate most Scut implements.
Time seems to be the key? My Ford 1500 @ 2000+ lbs with 9.5 X24" tires was considered  a Compact Utility when it was built in 1980.
By todays standards with 20 hp Diesel it would be considered on the lower side of the Scut range?
Edited by JD DANNELS, January 03, 2014 - 09:26 AM.
#12 twostep ONLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted January 03, 2014 - 11:39 AM
I thank these "classes" could also depend on the tractor's intended use...
Example: the 600 series Case tractors seem to be intended for more industrial use. The center tower sides ARE the loader uprights. I'm no expert but I doubt they were ever really intended to mow your yard or plow your garden.
Another example is my Kubota B5100E. It is outfitted like a CUT but much smaller, it's rated at 12hp (diesel), has 18" front tires and 27"-30" rear's. 3pt, 540pto, cutting brakes, trans mounts to tunnel mounts to engine (no frame rails). It's intended use was pulling tillers in the rice fields... meaning I would put it in the SCUT category even though it's lighter (950lbs) and weaker than some ALL of the SGT's.
Edited by twostep, January 03, 2014 - 01:48 PM.
  • JD DANNELS and Talntedmrgreen have said thanks
#13 OldBuzzard ONLINE
OldBuzzard
  • 7,018 Thanks
  • 4,790 posts
Posted January 03, 2014 - 01:46 PM
With Bolens, I would say that the 1886, HT18, HT20, HT20D, HT22, HT23 and HDT1000 would all qualify as SGTs.
They are all powered by multi cylinder engines varying from 18 to 23 Hp, have a 3-pt hitch available, are capable of pulling a 12" plow and other round engaging implements, and had both a FEL and Backhoe as available attachments.
I would hesitate to call them SCUTs, but they were creeping into SCUT territory.
Edited by OldBuzzard, January 03, 2014 - 01:47 PM.
  • twostep and OkieGt have said thanks
#14 Texas Deere and Horse OFFLINE
  • 14,799 Thanks
  • 15,495 posts
Posted January 03, 2014 - 02:22 PM
The Wheel Horse D-250 is a true SGT.
Engine- Renault 19.9hp 4 cylinder liquid cooled rated at 3000RPM
1,500RPM Front and Mid PTO- 1,000RPM Rear PTO
Wieght-1,260lbs
Trans, 4 forward 1 reverse with High/Low Range and Differential Lock
Automotive style Clutch and Individual Turning Brakes
The is was only rated at 19.9HP for some rule used in tractor ratings, in other uses the same engine is rated a just over 30HP.
  • KennyP, twostep and OkieGt have said thanks
#15 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted January 03, 2014 - 04:45 PM
I hope they don't' creep into SCUT territory they are tougher and stronger than SCUTS
  • Bill 76 said thank you
