Size Of Chains For Case 8-16 Tires
6 replies to this topic
#1 motobreeder OFFLINE
motobreeder
  • 427 Thanks
  • 615 posts
Posted January 02, 2014 - 11:21 PM
Hi,
I've been searching the internet, but I can't find the size of chains for my Case 444.
Hoping someone would know off-hand the correct dimensions.
Would like to know what size to watch out for.
Thanks.
#2 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted January 03, 2014 - 01:43 AM
Hi,
Thanks.
I believe 205/75/15s will fit, small truck chains in other words
  • motobreeder said thank you
#3 JDBrian OFFLINE
  • 9,594 Thanks
Posted January 03, 2014 - 07:10 AM
Did you try tirechains.com. Heres the 8x16 selection.  http://www.tirechain.com/8x16.htm
#4 motobreeder OFFLINE
motobreeder
  • 427 Thanks
  • 615 posts
Posted January 03, 2014 - 10:45 AM
Thanks, but I'm watching local ads and would like to know how wide and how long the chains should be for my big-wheel case.
Wondering if someone happened to know what width and length to be watching for.
  • OkieGt said thank you
#5 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted January 03, 2014 - 11:10 AM
Circumference is diameter multiplied by 3.14, Just punch the height of your tire into your calculator and hit the Pi button, you will need to add 4-6 inches for the latches. For the width, just add 2-3 inches to the width of your tire for wrap around, so around 100" x 12" might be pretty close, just doing in my head.
Edited by OkieGt, January 03, 2014 - 01:12 PM.
#6 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted January 19, 2014 - 12:07 AM
motobreeder,
Here's a link to a post from a while back. I have a '71 444 and once was in a similar hunt for info myself. After you take a look at the .pdf found through the link below let me know if you have any additional questions.
http://gardentractor...actor/?p=231914
#7 1031d OFFLINE
1031d
  • 32 Thanks
  • 90 posts
Posted January 22, 2014 - 10:12 PM
I have two sets of used chains in Wisconsin. Shoot me a PM if interested.
