2 Wheel Page
5 replies to this topic
#1 andy andy OFFLINE
andy andy
  • 41 Thanks
  • 44 posts
Posted January 01, 2014 - 07:20 AM
hello all
i was given this page tractor its in rough shape but i think i can fix that. the ser. number is z7  125012095  fs is any of this the model? and it has a clinton b700-fs on it if you all need more pics let me know
thanks andy in crumstown ind.
  • Gtractor, Alc, hamman and 3 others have said thanks
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 01, 2014 - 08:17 AM
There's a guy locally here who has a Page.  However, I think he has a Briggs Intek on it, much, much newer than the tractor.
If you need parts for the Clinton, let me know.  I have a carburetor that probably would work for it.
Ben W.
#3 Alc ONLINE
  • 7,126 Thanks
  • 7,530 posts
Posted January 01, 2014 - 08:20 AM
That's a neat machine !  I like the way the engine is mounted from the transmission , is the part sticking out the front for the sickle bar ? Good luck with your project !
#4 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted January 01, 2014 - 08:56 AM
Looks like mostly there, Looks like the Clinton is not original to the tractor unless the sump pan was swapped out.
The carb was a Carter N, not the later ones but early with the round float bowl, the muffler was the short one so commonly seen and treasured by Continental AU7 / AU85 collectors. The air cleaner assy was usually the clear Saf-T-View but could of been otherwise due to Page tractor specs.
I also see the Clinton has the early governor throttle bracket putting the engine in the early 1950's but not the late 1940's due to the screen around the recoil cup on the shroud.
  • Alc, andy andy and Sawdust have said thanks
#5 andy andy OFFLINE
andy andy
  • 41 Thanks
  • 44 posts
Posted January 01, 2014 - 09:07 AM
alc
the part sticking out the front is part of the sickle bar it has been broke off the sickle bar is in the center pic top
andy
#6 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,652 Thanks
  • 5,048 posts
Posted January 01, 2014 - 11:07 AM
AWESOME!!
Whenever I see something like that with turning brakes I start to thinking about a "crawler conversion"
:thumbs:
