3Pt Added To The 318
12 replies to this topic
#1 york0060 OFFLINE
york0060
  • 296 Thanks
  • 143 posts
Posted December 31, 2013 - 04:54 PM
My wife bought me a 3 pt assembly for my  318 for Christmas. i have it mounted and am ready to put it to use. I bought a older Sears single bottom plow and cultivator last spring, It is for a narrow 3 pt spacing (about 15 inches) so i am currently making a set of pin extension to make to wider that i can just bolt on and use. i will add some pictures later after they are made.
  • Alc, hamman, sacsr and 2 others have said thanks
#2 trowel OFFLINE
trowel
    Summer.
  • 4,820 Thanks
  • 4,533 posts
Posted December 31, 2013 - 05:31 PM
Great to hear (read) of the new plow and culti, looking farwards to the mods.
  • york0060 said thank you
#3 Talntedmrgreen OFFLINE
  • 3,122 Thanks
  • 2,213 posts
Posted December 31, 2013 - 05:34 PM
Well, that's fun!! Heck of a wife!
  • york0060 and michael.kitko have said thanks
#4 HowardsMF155 OFFLINE
  • 2,720 Thanks
  • 2,926 posts
Posted December 31, 2013 - 05:39 PM
This may not work since I'm not familiar with the variance between a real cat 0 like you have and the Sears "Cat 0", but can you turn your arms around so they spread "inward" instead of "outward" ?
#5 Cat385B ONLINE
    Therapy CAT
  • 12,533 Thanks
  • 9,288 posts
Posted December 31, 2013 - 06:33 PM
Where did you get the 3 point from? Ruegg? Heavy Hitch? Redlandhill? Jim's repair? Factory?
#6 TAHOE OFFLINE
TAHOE
  • 6,856 Thanks
  • 5,156 posts
Posted December 31, 2013 - 06:42 PM
I would be curious to see your adapters, I have all Sears sub Cat 0 implements and would like to use on my Cat 0 Massey
#7 michael.kitko OFFLINE
michael.kitko
  • 475 Thanks
  • 447 posts
Posted December 31, 2013 - 06:48 PM
Agree with great wife comment...
Sent from my ASUS Transformer Pad TF300T using Tapatalk 4
#8 KC9KAS ONLINE
KC9KAS
  • 5,007 Thanks
  • 4,418 posts
Posted December 31, 2013 - 06:54 PM
Nice to have a spouse that buys us GT goodies!
#9 Canawler OFFLINE
Canawler
  • 1,912 Thanks
  • 1,767 posts
Posted December 31, 2013 - 07:13 PM
Nice. Does that qualify as a Merry Christmas?
#10 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,548 Thanks
  • 4,071 posts
Posted January 01, 2014 - 06:36 AM
That's a real great christmas gift
#11 JDBrian OFFLINE
  • 9,593 Thanks
Posted January 01, 2014 - 08:22 AM
The hitch looks great on there. A 3pt is a great addition to any tractor. It really increases the versatility!
#12 york0060 OFFLINE
york0060
  • 296 Thanks
  • 143 posts
Posted January 02, 2014 - 09:24 AM
it is a Reimad 3 pt, I think the Ruegg would be a better one, its Rock Shaft is closer to the orginal JD design and i have read it is astronger built shaft. I was useing the lower arm to pull some saplings out of the ground and noticed that i twisted my Rock Shaft (Solid 1" thick shaft), i ground off the weld on the rock shaft lift arm and got it back in align with the Cylinder side lift arm then rewelded. I also welded and spine along the back side of the rock shaft to make it stronger. It should be better and I also learned a lesson on what to do and what not to do. I should have used both arms to pick up with anyway and not just the one. We learn from our mistakes.
#13 Cat385B ONLINE
    Therapy CAT
  • 12,533 Thanks
  • 9,288 posts
Posted January 02, 2014 - 10:58 AM
Thank you for the info and the review. I see there is a $60 price difference between the two. I had never looked at the Redlandhill hitch before, holy $$$$$$.
