Finally Got Elfs Big Brother Picked Up Today.. D-250
48 replies to this topic
#16 Texas Deere and Horse ONLINE
  • 14,896 Thanks
  • 15,517 posts
Posted December 30, 2013 - 10:17 PM
What does a D-250 use for a transmission?
Nice find, btw.
Cat, it has a 4 + R with a HI/LOW Manual Trans. Shaft driven and I am guessing a automotive style clutch, thru I haven't checked on that yet.
#17 glgrumpy OFFLINE
  • 8,848 Thanks
  • 8,035 posts
Posted December 30, 2013 - 11:24 PM
They ARE a lot diff than the other smaller D's.  No rear tin?  Did you ask if they took it off and might have yet?  Not sure how you would find that, might be making some for this. That rear frame sticking out would have to come off if mine, weights or not!  Wonder if something else was mounted on those beams?
#18 IamSherwood OFFLINE
  • 8,395 Thanks
Posted December 31, 2013 - 12:02 AM
That sure looks like a beast Brian. Congrats.
I see on the column, you have diff lock, on the right, Pto beside that, tranny hi/lo
to the left of the shifter. But, what is that 2 lever arrangement beside that?
#19 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,540 posts
Posted December 31, 2013 - 12:16 AM
Nice find... I would really like an ARK 500 for one of my GT14's... at a price I could afford!
#20 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted December 31, 2013 - 06:16 AM
That is a good score, Brian! I may have to come visit you yet!
#21 Alc ONLINE
  • 7,344 Thanks
  • 7,631 posts
Posted December 31, 2013 - 06:27 AM
Brian looks like the lever on the right for a diff. lock ?
#22 MH81 OFFLINE
  • 29,979 Thanks
Posted December 31, 2013 - 07:25 AM
Nice find Brian and what a quandary.
To un name the loader and move it to a BH or to restore the D and keep it a WH.
#23 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted December 31, 2013 - 07:52 AM
He can just drop it off here and not have to worry about it! :smilewink: :dancingbanana:
  • MH81, Texas Deere and Horse and twostep have said thanks
#24 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted December 31, 2013 - 07:59 AM
The rear end on that is most likely not the typical GT rear end we see in North America. It's probably something heavier. That Renault 4 cylinder engine was probably capable of some serious low RPM torque. That's a nice find Brian and it would make a great restoration as the diesel variant.
  • Texas Deere and Horse and KennyP have said thanks
#25 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted December 31, 2013 - 09:37 AM
My experience with the Renaults goes clear back to the Renault Dauphines imported during the late 50"s and early 60's I was not impressed with them at all;.
That said those engines were uses in more small equipment than one would think and I think they proved out to be pretty good engines.
My father-in-law had a Case 1830 skidloader with the Renault engine and I ran it a lot. Always started good reguardless of temperatures, and was a smooth running engine that did everything you could ask of it. If one can find parts it would not scare me at all.
What I wondered is if the later imported Le Car used the same engine without the gouverner and could easily be swapped?
Edited by JD DANNELS, December 31, 2013 - 09:38 AM.
  • Texas Deere and Horse and Rock farmer have said thanks
#26 Texas Deere and Horse ONLINE
  • 14,896 Thanks
  • 15,517 posts
Posted December 31, 2013 - 10:09 AM
gl, The rear seat pan was discarded at some point when the owner built the frame on the back. It's just bolted on and used to have a small metal barrel on it to hold ballast, but it rotted away. I will find a used fender pan for it at some point.
Will, I will look at it closer today as I move it around on the trailer to get the rest of our stuff back on the trailer to go home tomorrow. I want to find the ID tag, if it's still on it also.
  • IamSherwood said thank you
#27 Texas Deere and Horse ONLINE
  • 14,896 Thanks
  • 15,517 posts
Posted December 31, 2013 - 10:13 AM
Bobby, I had the same loader on my 1970 GT14 and it was a great loader tractor. If you had the tiller on the back it made it steer pretty easy, without the weight it was a real bear to steer.
  • twostep said thank you
#28 Texas Deere and Horse ONLINE
  • 14,896 Thanks
  • 15,517 posts
Posted December 31, 2013 - 10:15 AM
Kenny, You know you are always WELCOME to come down anytime!!
#29 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted December 31, 2013 - 01:04 PM
I'll bring my trailer so I can take the loader back home! :smilewink:  :thumbs: :dancingbanana: :firejumper:
  • Texas Deere and Horse and IamSherwood have said thanks
#30 IamSherwood OFFLINE
  • 8,395 Thanks
Posted December 31, 2013 - 02:48 PM
Does it have steering brakes.
It almost looks like it says "parking" above that "2 lever" arrangement.
