Small Welding And Soldering Project
8 replies to this topic
#1 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,504 Thanks
  • 1,077 posts
Posted December 30, 2013 - 02:19 PM
  Needed a scoop to remove ice from fishing hole and had this high carbon wire salvaged from a futon and figured it wood work well. Wrapped screen around wire and soldered it to ring, then trimmed off excess w/ the dremel. Made the handle from some scrap dowel rod I scrounged somewherevicky gun 025 (Small).jpg vicky gun 026 (Small).jpg .
                                          Mike
  • Alc, hamman, sacsr and 6 others have said thanks
#2 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
Posted December 30, 2013 - 02:21 PM
I bet that will work perfect for clearing out the hole! It looks like a badminton racquet. :D
  • hamman and JRJ have said thanks
#3 Sawdust ONLINE
Sawdust
  • 4,846 Thanks
  • 2,973 posts
Posted December 30, 2013 - 02:46 PM
Nice little project from what you salvaged. Did you put a pin through the handle to keep the wood from coming off, that would be terrible to go home with an empty handle. I did that to a handle I made one time, thought it would stay in but it didn't.  :mad2:
  • JRJ said thank you
#4 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,504 Thanks
  • 1,077 posts
Posted December 30, 2013 - 04:59 PM
  I squirted some gorilla glue in the hole before inserting the rod.
                                                  Mike
  • HDWildBill and Sawdust have said thanks
#5 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted December 30, 2013 - 06:13 PM
How thick of ice are you fishing through? What kind of fish do you take?
#6 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted December 30, 2013 - 06:32 PM
Please make sure the ice is safe, before you venture out there.
A young lad was lost, not far from here the other day.
  • Fabman and sacsr have said thanks
#7 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,504 Thanks
  • 1,077 posts
Posted December 30, 2013 - 10:12 PM
I don't go out on anything less than 4". Haven't been out yet but w/ all the cold we've had I'm sure it's at least 12" by now. We catch mainly trout. They taste lots better out of cold water.
Mike
  • Sawdust said thank you
#8 HDWildBill ONLINE
  • 8,917 Thanks
  • 8,645 posts
Posted December 31, 2013 - 10:56 AM
Wow!  I would have thought by now most everything up there would be frozen solid.
OSB, that is some good use of scrap.  I don't throw away anything I think I can use later just for this reason.  Good Job!
#9 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted December 31, 2013 - 04:38 PM
I always follow someone heavier than me when I go out on the ice.
You sure are right about fish tasting better when pulled from the ice.
We get trout,muskie,pike and bass in the area I fish at.At least that is what I am told.
