How Hard Is It To Put A Cub Cadet Drive Shaft Spring It For Pulling
5 replies to this topic
#1 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted December 29, 2013 - 11:48 PM
anyone do it without a press
#2 Jlaws OFFLINE
Jlaws
  • 556 Thanks
  • 368 posts
Posted December 30, 2013 - 12:23 AM
Its almost impossible and dangerous to do without a press , although I've done it with a vice ( not recommended ) .
I made a homemade spring compressor to install cub clutch springs . Its basically a long threaded 5/8 rod with two U shaped removable brackets on each end . Its safe and easy to make .
Also works with the clutch still in the tractor if your using a split locking collar with a pulling clutch spring .
I can take some pictures and get measurements for you tomorrow if your interested in making one .
  • MH81 and Dieselcubmike have said thanks
#3 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted December 30, 2013 - 09:24 AM
I use a vice on stock springs,but I would NOT recommend using one to install a pulling spring.
#4 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted December 30, 2013 - 11:36 AM
yes you can do that if you want jlaws thanks
#5 Grumpy OFFLINE
Grumpy
  • 748 Thanks
  • 624 posts
Posted December 30, 2013 - 02:17 PM
I have a press, but I do it in my lathe using the tail stock to press the shaft.
  • bobslx50 said thank you
#6 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted December 31, 2013 - 09:16 AM
When we used to pull cubs we added 396 valve springs in place of the stock springs. For $12 you will have just as stong as a Super cub red spring
