Ignition switch is a shocker
4 replies to this topic
#1 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted December 25, 2010 - 02:04 PM
I've had this problem before, but forgot why. I went to check for spark on the 1050 today and both hands got shocked, one hand on the key, the other holding the plug wire to a ground. A poorly insulated plug wire can cause this but is there something else I missed? This tractor has fresh paint everywhere is it possible that paint is keeping something from grounding out? Is the ignition switch suppose to be touching bare metal on the dash?
#2 olcowhand ONLINE
  • 44107 Thanks
  • 32302 posts
Posted December 25, 2010 - 02:29 PM
Some switches ground through the mounting for killing ignition, while others have a grounding wire from switch. I would be sure there is a solid ground connection from the body of the switch to frame.
#3 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted December 25, 2010 - 08:44 PM
:ditto:
It's the path of least resistance. If there is less resistance where you're touching the wire - then thru you - then to ground: wham.
I'm wondering if you had your hand resting on the block & the switch isn't grounded well. You would provide some of the ground path needed. IE: mild to medium shock
If it was an "ouch" or "huh" shock, I'd say this was the case... if it was an "%*&$^%$#*^%~" SHOCK, then I'd say you have a bad spot in the plug wire.
#4 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted December 26, 2010 - 02:41 PM
I ground the paint off the back side of the dash and all is good, and I have a great spark.
#5 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted December 26, 2010 - 08:34 PM
Glad to hear you got the problem solved
