Traded Into A Kohler Magnum 18 Hp Opposed Twin Help
29 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 28, 2013 - 06:52 PM
Got a hold of a horizontal shaft Kohler 18 hp opposed twin in supposedly running condition. I need some help (will get numbers off it soon). What Kohler came on the Craftsman Gt6000, and what adapter needs to bolt to the flywheel to make the swap from Briggs to Kohler?
Edited by wvbuzzmaster, December 28, 2013 - 09:13 PM.
#2 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 28, 2013 - 07:17 PM
Edited by wvbuzzmaster, December 28, 2013 - 07:18 PM.
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 29, 2013 - 03:04 PM
Anyone have any comment at all?
#4 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted December 29, 2013 - 03:08 PM
Sorry, no help here. My 1994 GT6000 has a vertical shaft Kohler twin on it.
#5 Alc ONLINE
  • 6,742 Thanks
  • 7,396 posts
Posted December 29, 2013 - 03:11 PM
I can't help you out much .   Have you taken the Briggs off yet ?
#6 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 29, 2013 - 03:14 PM
No, I haven't got all the parts to the kohler yet, it has a remote oil filter and it isn't in my possession yet, but he still has it, and it has my name on it. So not pulling an engine till I hear another engine running.
  • Alc and twostep have said thanks
#7 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted December 29, 2013 - 03:36 PM
I wish I could help you too but I have no info. Does anyone know which/when the engines changed from vertical to horizontal? I know where I can get a real nice gt6000 and might check it out if it's a horizontal shaft.
#8 JDBrian OFFLINE
  • 9,601 Thanks
Posted December 29, 2013 - 03:46 PM
That engine is very much like the KT series 2 engines. Those engines were used in the JD 317 and in some of the Cub Cadet models. The adapters for those tractors will likely fit the engine, but what do you need on the end of the adapter? Shaft diameter and keyway size or drive pin etc. would be needed to find a candidate for direct bolt on.  Having one made will run you big$$
#9 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 29, 2013 - 03:49 PM
I found the correct adapter off a magnum 20 for Ayp tractors on eBay, and going to check the pattern and buy it.
#10 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 29, 2013 - 03:50 PM
Mid 90s I think
#11 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 30, 2013 - 01:10 AM
I bought the adapter so should have that by the weekend.
#12 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
Posted December 30, 2013 - 02:56 AM
I have no idea about the swap, but that looks like the engine in my 6000.
  • wvbuzzmaster said thank you
#13 MH81 OFFLINE
Posted December 30, 2013 - 06:17 AM
Casey, glad to hear you are getting an engine you feel more comfy with. I've been feeling bad for you that the briggs is such a PITA, especially after you've been so good to it.
The vert to horizontal change had to be between 88 and 95, but not sure beyond that. We had an 88 that was horiz and I have a 95 that's a vert. It would've happened whenever Electrolux took over building for Sears, but IDK the year.
Good luck with the swap.
  • twostep said thank you
#14 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 30, 2013 - 04:28 PM
Ran the codes of my magnum and learned it was built in 1988, same year as the Caterpillar, scary good sign lol.
#15 wvbuzzmaster OFFLINE
  • 4,716 Thanks
By the way, i have yet to get it out of the truck lol.
