Got Ol Red Running Again!
4 replies to this topic
#1 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,334 Thanks
  • 1,519 posts
Posted December 28, 2013 - 12:59 PM
Super excited so I had to post about it! :D So after fiddling with it for awhile while dad had company over I decided to tinker and got it to run. Still had to start it like I explained the other day. A loose spark plug doesn't always help Lol! the wiring will still need to be gone through but it does run. Had to adjust the points because the motor was really working at an idle. Will have to take that stupid pulse pump off and either directly connect the fuel lines to the carb or put an after market pump on it. I have a feeling that's what's causing some of my problems. It runs for a bit then wants to shut off and can be a bit to start again so im thinking its the fuel pump now.
  • MH81, OldBuzzard, Alc and 1 other said thanks
#2 glgrumpy ONLINE
  • 8,156 Thanks
  • 7,588 posts
Posted December 28, 2013 - 01:18 PM
No pump on any of mine, BUT, sometimes you need to keep the gas tank mostly full to get the flow down to carb. My line does do a little down and then up swing to carb and tank never completely MT's  then.  Is this a V-twin Briggs??  Didn't think the singles had a pump on them, but once had a White 990 that had newer V-twin and the pump in it. I'm also assuming you have that big long tank under hood. If you have newer one, maybe in back under seat?? Then, think you would need pump for sure.
  • Dieselcubmike said thank you
#3 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,334 Thanks
  • 1,519 posts
Posted December 28, 2013 - 08:54 PM
Actually no it was supposed to have the 16hp cast iron single cylinder Briggs on it. The prior owner installed a 10hp kohler on it instead.
#4 MH81 OFFLINE
  • 29,938 Thanks
  • 29,754 posts
Posted December 28, 2013 - 08:57 PM
Good to hear its running.
#5 OldBuzzard ONLINE
OldBuzzard
  • 6,838 Thanks
  • 4,737 posts
Posted December 28, 2013 - 09:44 PM
     Pics, or it didn't happen     :tapping_fingers:
:D :D :D
