1966 Chief 1000
40 replies to this topic
#31 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted December 29, 2013 - 11:02 AM
Thanks guys..
I obtained some 85w/140 this morning.  The manual says ep140 or ep 250w gear oil. I put it in the reverser gear.   I sanded the pto drive pulley with sandpaper this am ,it was rusty. Maybe it will be more slippery now.  I am going to think on the belt for a couple of days...Yesterday I saw an inch and a half crack in the generator bracket at the engine( I'll weld it later).  Additionally, the right hub is seized on.   I have Kroiled it and heated the axle with a propane torch briefly. Tapped with a hammer.  Now just sitting with Kroil.
Mike
#32 NCP17237 OFFLINE
NCP17237
  • 1 Thanks
  • 5 posts
Posted March 17, 2014 - 01:25 PM
Mike125s
How did you make out? I'm having the same issue with grinding gears and am also missing belt guides. Did that fix it?
  • Mike125s said thank you
#33 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted March 17, 2014 - 03:22 PM
Mike125s
Yes
The gears were grinding because the tranny was not stopped with the clutch in.  This is because belt guides were missing.  Once I installed a belt guide below the PTO pulley,the grinding stopped.  This is because the trans actually stopped turning when the clutch was depressed. BTW my tractor actually has a wheel horse pto or something. The jacobsen ones have the pto  pullies  that are more than one piece.  The belt guides keep the belt round when slacked.
Mike
#34 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted March 17, 2014 - 03:23 PM
Yes
Mike
PS  I made the belt guide out of angle iron
Mike
#35 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted March 17, 2014 - 04:20 PM
Mike
The other guides would be made out of a threaded bolt ground off or something like that.  Good luck!
Mike
#36 NCP17237 OFFLINE
NCP17237
  • 1 Thanks
  • 5 posts
Posted March 17, 2014 - 07:14 PM
Great. Thanks for the info and pics.
#37 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted March 18, 2014 - 07:10 PM
If you have not already, I would check to see the distance between the WH? pto has the same side to side distance from the side of the engine as the Jake did. If it does not, the belt may drag on the sheave not allowing it to fully disengage when pedal is pushed in. Stiemmy
#38 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted March 19, 2014 - 09:08 AM
Stiemmy,
I have not tried the PTO with the deck yet.  It has to be welded in a few places around the pulleys.  I will keep that in mine thanks!!
Mike
  • stiemmy said thank you
#39 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted March 19, 2014 - 07:52 PM
:thumbs:
#40 Jarret53 OFFLINE
Jarret53
  • 16 Thanks
  • 15 posts
Posted April 06, 2014 - 05:33 PM
I just picked up a 1970. Gonna be parting it out so let me know if my tractor can help yours!
#41 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted April 07, 2014 - 06:39 AM
Stiemmy,
Mike
PS Deck belt works with Wheel Horse pto pulley!
Mike
