1966 Chief 1000
40 replies to this topic
#16 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted December 28, 2013 - 08:30 PM
yes when brake/clutch down , brake stops(right side trans). Drive pulley on left side of trans keep spinning.  Also trans gears keep rotating(preventing gear selection without grinding)  Thanks
Mike
#17 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted December 28, 2013 - 08:42 PM
That's the oil it calls for so you should be fine there.  I can't tell for sure from the photos but it looks like the belt guide that sits behind the PTO pulley may be missing, That might be part of your problem if so.
When you mash the clutch pedal all the way down with the engine running, does it stop the brake drum but the input pulley keeps turning?  Unfortunately mine is all torn apart (a thread will be up on that shortly) so I can't check to see what mine does...
I checked ,there is a threaded hole in the block behind the pto pulley. You have a good eye.  I could make another belt guide.  I'm not sure if that would stop the trans from turning with the brake/clutch in?? I'll try it Thanks much
Mike
#18 Walkinman1 OFFLINE
Walkinman1
  • 770 Thanks
  • 589 posts
Posted December 28, 2013 - 08:48 PM
I'll grab a picture of mine after supper tonight, give you an idea of what it should look like.
#19 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted December 28, 2013 - 09:14 PM
I don't know if there is room by the pto?  Maybe the previous owner put a bigger pulley on then removed the belt guide.  It looks to be very close
Mike
#20 Walkinman1 OFFLINE
Walkinman1
  • 770 Thanks
  • 589 posts
Posted December 28, 2013 - 09:28 PM
It's a very tight fit, yours may still even be in there.
This is a view from the front, you can just barely see the drive belt behind the guard...
View from the back, I pulled the PTO belt off so you can see where the guard ends on the bottom...You can just barely make it out below the drive belt.
#21 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted December 28, 2013 - 09:34 PM
Thanks I did not look there.  I'll have to go back and look again.. Thanks for all the help!!
Mike
#22 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted December 28, 2013 - 09:38 PM
Belt guide by pto pulley is missing.thanks!
Mike
#23 Walkinman1 OFFLINE
Walkinman1
  • 770 Thanks
  • 589 posts
Posted December 28, 2013 - 09:42 PM
I'd double check the belt length and also how much slack you have when the clutch is pressed. Superaben gave me a great point earlier that if there's a groove or wear in the pulleys it will hold onto the belt even with no tension. Tommy Williamson has a chief 1200 that he's parting out, you could see if he has a guard that he'll sell?
  • Mike125s said thank you
#24 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted December 29, 2013 - 07:09 AM
I accidentally put 90w oil in the  reversing box,I have to go get some ep 250w oil before I test again.  I will measure the belt too,maybe it is too short?  THX
Mike
Genoa,IL
#25 MH81 OFFLINE
  • 29,979 Thanks
Posted December 29, 2013 - 07:11 AM
EP250w? Whew, never seen that in person.
Bet it pours like asphalt.
#26 Walkinman1 OFFLINE
Walkinman1
  • 770 Thanks
  • 589 posts
Posted December 29, 2013 - 07:19 AM
My reversing box had nothing but some brown sludge in it when it came apart and I hadn't looked up the fluid spec for it yet...guess that explains it lol, it's asphalt!
#27 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted December 29, 2013 - 07:23 AM
Maybe I should get some 80w/140 then? I have been unable to find ep250w on the computer(Menards,Farm and Fleet) Thx
Mike
Genoa,IL
#28 MH81 OFFLINE
  • 29,979 Thanks
Posted December 29, 2013 - 07:25 AM
Best wait to find someone who knows, but if it needs to be that thick, maybe grease? IDK
#29 Walkinman1 OFFLINE
Walkinman1
  • 770 Thanks
  • 589 posts
Posted December 29, 2013 - 07:42 AM
I did some quick looking and supposedly Redline Shockproof Heavy gear oil has a 250 weight rating. 250 is still available but seems to be mostly industrial applications thus you'd be buying 5 gallons of it at a minimum.
#30 MH81 OFFLINE
  • 29,979 Thanks
Posted December 29, 2013 - 08:10 AM
Found this, but at 70/ gal I would consider other options.
http://www.mscdirect...&searchterm=250
