Gas Powered Battery Charger/jumper
13 replies to this topic
#1 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted December 27, 2013 - 06:33 PM
Smash em' mash em' project, at uncle's shop using nothing but scrap/parts from around, borrowed camera for pic's.
Just has to work or be a flop, don't care, can modify at discretion.
Sits on extra soft anti-vib mounts from oxygen condenser compressor.
Briggs 92500 series, 3 hp with auto-choke carb. Delco Remy 65 amp alternator.
  • hamman and boyscout862 have said thanks
#2 KennyP ONLINE
  • 41,519 Thanks
  • 47,427 posts
Posted December 27, 2013 - 06:37 PM
That should work!
  • trowel said thank you
#3 MH81 OFFLINE
  • 29,979 Thanks
Posted December 27, 2013 - 06:54 PM
I've seen similar with a L&G or small car batt for a buffer. They used it and liked it.
There was another thread a while ago with plans kinda.
#4 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted December 27, 2013 - 07:10 PM
Web full of plans, several ways of going about it, purely charge/jump or with inverter for AC, many off-gridders use with wind/solar.
My first charger/jumper with Delco Remy CS121 alternator.
#5 UncleWillie OFFLINE
  • 16,421 Thanks
  • 9,035 posts
Posted December 27, 2013 - 07:17 PM
Nice rig. I need something like that.
#6 MH81 OFFLINE
  • 29,979 Thanks
Posted December 27, 2013 - 07:24 PM
Next Chevy with a 10si or bigger alt, there you go.
#7 UncleWillie OFFLINE
  • 16,421 Thanks
  • 9,035 posts
Posted December 27, 2013 - 07:36 PM
I have a couple of them. I just need time and motivation now.
#8 MH81 OFFLINE
  • 29,979 Thanks
Posted December 27, 2013 - 07:41 PM
Ok, hows this: no more coffee until its done...
:rolling:
  • KennyP and trowel have said thanks
#9 UncleWillie OFFLINE
  • 16,421 Thanks
  • 9,035 posts
Posted December 27, 2013 - 07:46 PM
  • MH81, KennyP, HowardsMF155 and 2 others have said thanks
#10 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted December 27, 2013 - 08:06 PM
:thumbs:
#11 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted December 27, 2013 - 08:38 PM
Nice little setup.  I ought to build one, too, for all the mumbling I do about battery jumpers and extension cords.
I've got an old Delco small (probably less than 2 1/2 hp I would think) plant that is supposed to be hooked up to a battery as a mobile jump.  I have never got it worked on.
Ben W.
#12 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted December 27, 2013 - 08:44 PM
Like this ?
#13 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted December 28, 2013 - 09:38 PM
Yeh, more stuff happened,
Alternator lined up and mounted, idler pully linded up and mounted, control panel mounted, inverter will be mounted underneath the cover.
#14 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted December 28, 2013 - 10:09 PM
More pic's of the alternator mount and idler pully.
Cast iron flywheel replaced the alloy one, started taking off the recoil clutch, took a pic and was distracted :bigrofl: by the old fart ripping around in the snow on his butt-buggie,  forgot to get pic's of reassemble of flywheel, i was :bigrofl: too hard !
Another day at the shop :dancingbanana:
