Info On 14 Xx Series
#16
OFFLINE
Posted December 26, 2013 - 08:14 PM
#17
OFFLINE
Posted December 26, 2013 - 09:41 PM
it's a pretty easy job to inspect the transmission internals. Remove the seat, fender, and tool box. Then the top cover of the transmission comes right off by removing several bolts and lifting it up and off. As mentioned, it may be something very easy to fix - roll pin sheared in shifter, shifter or shifter gear broken, etc. Maybe drain the gear oil and remove the bottom cover to see what pieces/parts settled to the bottom. After assessing the damage, then make the decision about repairing or replacing with a used transaxle. Good luck.
- MyBolens1053 said thank you
#18
OFFLINE
Posted December 26, 2013 - 10:30 PM
#19
OFFLINE
Posted December 27, 2013 - 12:19 AM
Nice find and hope you get it running well. Snowblower for tubeframes seem to be a common item. Cabs are a little harder to find. But, that's over here on the east coast. Wheel weights you can find easily. Chains are common, too.
If you can snag it for $200 (in my opinion) you'll do okay with adding cost for another trans.
As for getting back your money IF you sell it after fixing it, that'll depend on time, current market demands, etc. Some guys don't consider what use they got out of it and feel they should get top dollar for something that they can't say will last another 50 hrs. of run time. Best to just enjoy it while you have it.
Best way to say it is "Use the tools, not the people."
Good luck.
#20
OFFLINE
Posted December 27, 2013 - 10:44 AM
$200 would be a steal in my opinion just for the cab and the snowblower. I know it varies depending on location but the cab alone should be worth $200 by itself, and as time goes on it will only gain in value. I don't wanna get into "what it's worth" because that is personal opinion, but I would personally pay more than that because of the cab and snowblower. The G14 was produced from '72 to '78, so there are plenty of them out there sitting in fields with bad motors and good transaxles. The 1254 I believe has the same transaxle. It seems like you should be able to find one with a little searching and patience. Good luck, hope to see pictures of it after you pick her up.
#21
OFFLINE
Posted December 27, 2013 - 10:52 AM
To late you aready did.
- Oregon_Bolens said thank you
#22
OFFLINE
Posted December 27, 2013 - 11:04 AM
My bad
#23
ONLINE
Posted December 27, 2013 - 11:07 AM
G14 was made 1973-1978
Any 6 speed transmission will adapt
#24
OFFLINE
Posted December 27, 2013 - 11:14 AM
Sorry, 1254 was produced in '72. Regardless, many of them out there.
I'm gonna go crawl back into my hole now.
#25
ONLINE
Posted December 27, 2013 - 11:15 AM
Thats ok
Just trying to keep stuff as accurate as possible
#26
OFFLINE
Posted December 27, 2013 - 11:49 PM
- boyscout862 said thank you
#27
OFFLINE
Posted December 27, 2013 - 11:53 PM
#28
ONLINE
Posted December 28, 2013 - 09:14 AM
How well do they push a blade? What is correct motor? Anybody run these in parades I live in small town and sometimes you see the vintage ones pulling small floats.
The G14 Should have a Tecumseh HH140 (14HP) Engine
There are some people that take these to shows/Parades
They are built like mini tanks and will push/pull just about anything you would want them to do (Just don't try moving a house with them )
#29
OFFLINE
Posted December 28, 2013 - 07:23 PM
After I got it load after purchase the guy handed me original owners manuals for tractor and blower along with the dealer prep instructions!
