For Sale
2.2 Caterpillar Engine For Gt Puller Ny
2 replies to this topic
#1 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted December 24, 2013 - 05:59 PM
2.2L CAT engine has been turbo charged, and the head shaved a wisker. MICH. diesel figured after honing injectors the Cat should produce 230HP @ 5psi@3200rpm. $400 to have them hone the injectors.  had a local shop shave the head. its BRAND NEW - 15 hours it ran to brake-in the engine. Not a Reman Also has adaptor plate on the rear to mate upto a chevy trans
Can deliver to Columbus Ohio or on the way.                 $1500
Edited by baerpath, December 24, 2013 - 06:00 PM.
  • Dieselcubmike said thank you
#2 olcowhand ONLINE
  • 41,086 Thanks
  • 31,402 posts
Posted December 24, 2013 - 06:27 PM
WOW....I need that engine in my Cat 910 payloader!
#3 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted December 24, 2013 - 07:56 PM
It could be set back to be able to use it that way,just pull the turbo off and run it as a NA engine. The injector and pump work will make it burn a little extra fuel though
