Well....the Ad Did Say It Broke A Rod
14 replies to this topic
#1 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,227 Thanks
  • 1,083 posts
Posted December 24, 2013 - 02:19 PM
A couple of months ago a 214 Deere popped up on craigslist the seller said he was confident something internal had broke,he had it at a great price so I brought it home.I just recently got a chance to drop the pan and all I can say is the seller was correct! That's as far as I've gotten into it,things looked good from top side but what little I could see pan side didn't look promising,it appeared there may be a chunk out of the bottom of the cylinder.
  • boyscout862, Dieselcubmike, oldedeeres and 1 other said thanks
#2 MH81 OFFLINE
Posted December 24, 2013 - 02:35 PM
Yuck, that's nasty. Sorry to hear it, hope it isn't anything that will keep you from saving the engine.
  • pigsitter said thank you
#3 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 24, 2013 - 02:42 PM
Looks like it is time to put your talents to good use! :smilewink:   Hope you can save the engine.
#4 pigsitter OFFLINE
pigsitter
  • 1,227 Thanks
  • 1,083 posts
Posted December 24, 2013 - 02:47 PM
I got to hear it turn over before I bought it so I went into the deal thinking parts tractor,but I've got to agree it would be nice to be able to save it.
#5 pigsitter OFFLINE
pigsitter
  • 1,227 Thanks
  • 1,083 posts
Posted December 24, 2013 - 02:55 PM
Thought you guys might enjoy a few pics of my improvised engine hoist as well.
A tire iron,a set of strap type come a longs,a doublesided 6' ladder and ta da! :smilewink:
  • KennyP, jimbobbillyray, boyscout862 and 4 others have said thanks
#6 farmer john OFFLINE
farmer john
  • 1,775 Thanks
  • 902 posts
Posted December 24, 2013 - 03:22 PM
thats ugly, and the broken rod is pretty bad too, maybe you should get a horse,
#7 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted December 24, 2013 - 03:27 PM
You might have been able to straighten it if it would have just bent.
  • pigsitter and superspeedex have said thanks
#8 olcowhand ONLINE
  • 40,374 Thanks
  • 31,177 posts
Posted December 24, 2013 - 03:43 PM
If it's just a small chunk broken from the cylinder, then it won't prevent using the block.  Often I will just use a dremel & stone, or just a round file to chamfer the edges of the broken out area.  Never had an issue doing this, and done it with chunks missing as deep as 1/2" and 3/4" wide.
  • pigsitter and oldedeeres have said thanks
#9 pigsitter OFFLINE
pigsitter
  • 1,227 Thanks
  • 1,083 posts
Posted December 24, 2013 - 04:13 PM
Funny you should say that as I recently did,now that I've got free time on my hands I'll see if I can get some pics posted of it.
#10 pigsitter OFFLINE
pigsitter
  • 1,227 Thanks
  • 1,083 posts
Posted December 24, 2013 - 04:22 PM
If it's just a small chunk broken from the cylinder, then it won't prevent using the block.  Often I will just use a dremel & stone, or just a round file to chamfer the edges of the broken out area.  Never had an issue doing this, and done it with chunks missing as deep as 1/2" and 3/4" wideI
From what I can see it's not very big and I won't swear the rod breaking was the cause as I've not found the missing piece,neither in the block nor in the oil.
#11 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted December 24, 2013 - 04:44 PM
I don't know much about JDs, but I'd say that rod might be bad...
I like your engine lift though, looks like it worked just fine.
#12 Traill95 ONLINE
Traill95
    Traill95
  • 1,845 Thanks
  • 1,008 posts
Posted December 24, 2013 - 06:27 PM
Jeff Foxworthy would be proud of the engine lift. :bigrofl:
  • jimbobbillyray, pigsitter and oldedeeres have said thanks
#13 KC9KAS ONLINE
KC9KAS
  • 5,329 Thanks
  • 4,672 posts
Posted December 24, 2013 - 06:47 PM
Hey, great engine lift!
What-ever we have, we use!
#14 KennyP ONLINE
  • 37,525 Thanks
  • 45,518 posts
Posted December 24, 2013 - 07:01 PM
Cool engine lift! Hope you can salvage the block!
#15 UncleWillie ONLINE
  • 15,536 Thanks
  • 8,711 posts
Posted December 24, 2013 - 11:24 PM
Well he didn't lie at least
