Engine Replacement Bolens 1220
1220 tecumseh replace
20 replies to this topic
#1 Mike Unwin OFFLINE
Mike Unwin
  • 405 Thanks
  • 304 posts
Posted December 24, 2013 - 10:01 AM
Morning All,
 Yesterday I had a bit of trouble the starter drive came off the engine while the Tecumseh 12 hp was blowing snow it quickly destroyed the flywheel .I remove the engine from the old 1220, I tried searching the forum for a replacement story but came up short.Someone had the same tractor but unknown how it ended up.
Does any one know what would basically bolt in ? I was hoping for a Briggs or Kohler replacement . Sort of need this working as we are having a old fashioned winter .Any information would be great it is - 16 out there this morning but supposed to warm up a little slowly. Even if I could find a flywheel sooner or lately I would be facing either a blown engine or dead ignition. Thanks Mike
#2 Bolens 1000 OFFLINE
  • 15,445 Thanks
  • 18,290 posts
Posted December 24, 2013 - 10:05 AM
As much as I hate swapping out the original engine..... I would personally look for a 12HP wisconsin (TRA12D) to put in its place.
That will bolt right up and no hacking of the hood or sheet metal would be necessary.
  • Mike Unwin said thank you
#3 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted December 24, 2013 - 12:47 PM
Not to mention the fact that a Wisconsin is a much better engine than anything else you can get now.
Ben w.
#4 Mike Unwin OFFLINE
Mike Unwin
  • 405 Thanks
  • 304 posts
Posted December 24, 2013 - 02:22 PM
The trick of course is to get one,really can,t complain the the Tecumseh was 43 years old and it was the starter drive that knock it out.I will keep looking something will turn up. Merry Christmas to All.
#5 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,169 posts
Posted December 24, 2013 - 02:33 PM
Why not just replace the flywheel and fix the starter? Was there something wrong with the tecumseh
#6 Mike Unwin OFFLINE
Mike Unwin
  • 405 Thanks
  • 304 posts
Posted December 24, 2013 - 04:37 PM
Around here it means trying to find another Tecumseh which would be as hard as finding another engine that would not have the module troubles that you can get.I do have a newer square type starter if that,s what happens the engine could be repaired. Maybe that is what I will have to do patch the original engine till  spring.
#7 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted December 24, 2013 - 06:07 PM
I have a dead 8 hp Tecumseh engine from a snow blower sitting in my shed.  If you think it will work, I'm just up the 401 from you.
#8 truckintyler OFFLINE
truckintyler
  • 90 Thanks
  • 63 posts
Posted December 24, 2013 - 07:41 PM
Have a oh140 with a knock, pm me
#9 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted December 24, 2013 - 08:43 PM
You can always but a 32v cummins in it
#10 Bolens 1000 OFFLINE
  • 15,445 Thanks
  • 18,290 posts
Posted December 24, 2013 - 10:49 PM
ummm..... No comment :hitting_self_roller:
#11 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted December 24, 2013 - 11:33 PM
:poke:  :smilewink:
#12 Mike Unwin OFFLINE
Mike Unwin
  • 405 Thanks
  • 304 posts
Posted December 25, 2013 - 10:42 AM
Well now I am sick , as years go by it,s trick just to get thru Christmas least I have power last I heard approx 200,000 dont. And baby it is cold outside -14 today.Thanks guys I will get back to it. Cheers Mike
#13 Mike Unwin OFFLINE
Mike Unwin
  • 405 Thanks
  • 304 posts
Posted January 04, 2014 - 04:41 PM
So yesterday I was feeling better so I went outside and pulled the 12 HP Tecumseh out of a dead 1976 Sears tractor,carried it into the basement and lugged down a 12 volt battery and booster cables pulled the spark plug and briefly cranked it several times.It had great spark ! So the guys problem was the ratty wiring in his old tractor.The Sears had a beautiful muffler too bad it would not fit.After changing the governor linkage over thought this will work !! Then after pulling both pulleys off the two engines found the Bolens 1969 had a 1 inch crank and the 1976 Sears had a 1 1/8 inch crank !! Dang ! All that for nothing back to the drawing board.Don,t know if the machine shop can open up the Bolens pulley and make a new key way. Cheers Mike
#14 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
Posted January 04, 2014 - 05:59 PM
This is an older ad, and he has other Bolens for sale, maybe he has what you need. ???
http://barrie.kijiji...QAdIdZ462464537
Edited by DH1, January 04, 2014 - 05:59 PM.
#15 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted January 04, 2014 - 06:09 PM
Bolens Husky also had the Wisconsin 12D, should be a direct drop in replacement, what state are you in ? i know were there is a Bolens with Winnie engine, can be had cheap, Steve keep trying to get my to buy it.
http://www.google.co....58187178,d.cGU
My S12D below :
Edited by trowel, January 04, 2014 - 06:12 PM.
Also tagged with one or more of these keywords: 1220, tecumseh, replace
