Briggs Vacu-Jet, Slide Choke ... Atmospheric Vent?
4 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted December 22, 2013 - 01:30 PM
My 2 Hp Briggs (60102 1015 01) has what I believe is a Vacu-Jet carb with slide choke.  I'd like to soda blast and clear coat it (I do like shiny things).  Does it have an atmospheric vent that I need to worry about clogging?  If so, where is it?
#2 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted December 22, 2013 - 04:28 PM
There's no float bowl and no diaphragms, so there will be no atmospheric vent.  The vacu-jet just siphons gas straight from the tank.  The fuel cap is the weak point of the system, since if it is clogged the carburetor will not syphon.
Ben W.
  • Alc and New.Canadian.DB.Owner have said thanks
#3 markcunningham OFFLINE
markcunningham
  • 2 Thanks
  • 9 posts
Posted May 09, 2015 - 08:51 PM
Hi, I'm a newbie here and would like to know if you knew about these Vacu-jet carbs and can I get a new or used one somewhere or could I use a pulse-jet carb instead. Reason being that the throttle plate inside of my vacu-jet slide choke carb is sticking wide open and rubs stiff when i close it to the stop. Obviously not good for the linkage. Any help is good help in my eyes.
Mark C Cleveland OH
#4 bbuckler ONLINE
bbuckler
  • 3,476 Thanks
  • 3,069 posts
Posted May 12, 2015 - 10:06 AM
Mark C Cleveland OH
you might be able to find one used but I don't think you can find a new one even clone. Try soaking the carb one in carb cleaner for awhile
Edited by bbuckler, May 12, 2015 - 10:08 AM.
#5 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted May 26, 2015 - 08:39 PM
Mark C Cleveland OH
I have had that happen when I have rebuilt the carb & installed the fly (throttle plate) up side down.
