Some Assembly Required, Batteries Not Included
5 replies to this topic
#1 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted December 21, 2013 - 08:31 PM
Hi all, here are some pics of the wheel horse 520h i traded for, turnes out its a 520hc, are the swept forward front axels on all 520s, are these units just dressed down 520s, what are the differances? this should keep me out of trouble for a while, the blade is real good and the deck only needs a minor patch, i will need a new ignition mod, but i will do a compression check first as i dont want to rebuild the onan as they are too expensive for parts, i would rather put a harbour frieght diesel into it. thanks farmer john
  • hamman, boyscout862 and JRJ have said thanks
#2 MH81 OFFLINE
Posted December 21, 2013 - 08:41 PM
Looks like someone lost the assembly directions and gave up... :D
Sounds like there is lots of potential and the hydro will be nice for you too.
As for e ONAN, don't write it off yet.
  • farmer john said thank you
#3 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted December 21, 2013 - 08:42 PM
No, not all 520's were built with the forward swept axle, but I can't tell you what year/model does or dose-not.
There is also a steering gear reduction that assists steering with a loader.....I think!
I would think you have done well with this WH 520!
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted December 21, 2013 - 08:54 PM
Nice tractor. The frame is really narrow on those. I'm used to looking at the JD's with the box type front frame which is much wider.
#5 glgrumpy OFFLINE
  • 8,612 Thanks
  • 7,920 posts
Posted December 22, 2013 - 01:29 AM
Think that snow blade has an extension on the rear of frame to let it clear the wheels if blade is turned. Make sure you keep that with it. Might be pinned on it now?  Can't see it in the pix, just heard that. I had extension once, hard to get and expensive, so keep it safe.
#6 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,823 Thanks
  • 2,782 posts
Posted December 22, 2013 - 06:20 AM
That will be a great gt when reassembled.  Those 520 WheelHorses are fine tractors.  :thumbs:
