What I'm Waking Up To!
67 replies to this topic
#46 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted December 22, 2013 - 07:14 AM
Will that is where the gravel has settled. Aaron needs to get a couple more loads of gravel hauled in. He has never graded the drive, so anything I work up would have a lot of grass & roots in it. I hope to kill the grass in the middle next spring so I can work the hump over and smooth it out.
Got a grader blade in the planning stages, just too cold to work on it right now!
#47 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted December 23, 2013 - 10:21 AM
I went out and looked around. Bubba has about 3/8" to 1/2" of ice covering him. The sun is trying to poke out of the clouds, hope it does to melt some of this. I put Willie in the Tractor Port, but the door track is frozen up. Couldn't get him out if I wanted to. Oh well, may get into the forty's tomorrow!
  • HDWildBill and boyscout862 have said thanks
#48 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted December 23, 2013 - 11:17 AM
I went back out and took a few more pics. Poor Bubba!
Here's a couple of the neighbors carnage:
And the sun is coming through:
  • IamSherwood, MFDAC and boyscout862 have said thanks
#49 Walkinman1 OFFLINE
Walkinman1
  • 767 Thanks
  • 583 posts
Posted December 23, 2013 - 12:17 PM
That's brutal Kenny! At least you've got some firewood now, well, once you can get a tractor going to drag it home...
#50 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted December 23, 2013 - 12:36 PM
It's all Elm wood! Not good for heat! But will make a good wiener roast. Maybe some marshmallows too!
#51 boyscout862 ONLINE
  • 12,852 Thanks
  • 9,172 posts
Posted December 23, 2013 - 12:44 PM
Elm is okay for heat. The problem is the splitting. Elm does not split from the center out. You have to slab off pieces around the outer edge. The resistance to splitting is why Elm was used for wooden wheel hubs. Good Luck, Rick
  • IamSherwood, KennyP and TomLGT195 have said thanks
#52 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted December 23, 2013 - 02:29 PM
So much for anything melting as it is snowing again! :wallbanging:  :(  :mad2:
#53 olcowhand ONLINE
  • 41,154 Thanks
  • 31,417 posts
Posted December 23, 2013 - 02:32 PM
I know too well how damaging an ice storm is, but I can still appreciate the beauty of it when the sun hits all that ice.  Just be careful Kenny!  Mother nature put it there, and only mother nature can take it off.
#54 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted December 23, 2013 - 02:35 PM
I just checked and the wind chill is 17* (-8C). But it's gonna be warmer tomorrow. I'm not out much, Daniel. Just have to get out for a bit every so often!
#55 IamSherwood OFFLINE
  • 8,391 Thanks
Posted December 23, 2013 - 07:01 PM
Have you seen any news about the mess they're in, in Toronto?
I just talked with Doug. Sounds like a war zone. People stealing
salt from each other. 1" of ice on the trees, and they're snapping
off. No warmth in sight, before Wednesdays snow and wind.
That's going to make matters worse. Not good.
#56 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted December 23, 2013 - 07:09 PM
Hadn't heard anything! Thanks, Will!
#57 olcowhand ONLINE
  • 41,154 Thanks
  • 31,417 posts
Posted December 23, 2013 - 07:52 PM
It was about an inch of ice (maybe a bit more) that destroyed timberland around here a few years ago.  That much ice is devastating to trees, and most everything that can break will.  Nobody was stealing salt down here that I heard of though!
#58 UncleWillie OFFLINE
  • 15,670 Thanks
  • 8,761 posts
Posted December 23, 2013 - 10:09 PM
Why did you let my tractor freeze?
#59 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted December 24, 2013 - 07:59 AM
It'll thaw out today, Willie. The one named after you is under the tractor port, but the door is frozen shut!
#60 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted December 24, 2013 - 10:22 AM
I hope it gets above freezing today Kenny.  I could use my county road as a bobsled course.
