Jd 317 Engine Repair Options
17 replies to this topic
#1 adolmsted OFFLINE
adolmsted
  • 5 Thanks
  • 8 posts
Posted December 20, 2013 - 10:28 PM
Howdy folks, just picked up very nice 317 with a very blown kt17 series one engine. Looking for some advice. My initial thoughts are to try to obtain a series 2
II case and crank and go from there. The engine had less than an hour on a partial rebuild, so there are a lot of good parts.
I currently have a jd214 that is my workhorse complete with snowblower, tiller and bagger. I just retired from the navy last year and picked it up to take care of my property.
I will post some pictures when I get to my PC.
Thanks in advance guys, I look forward to being an active part of GT talk.
Andy
  • Texas Deere and Horse and sacsr have said thanks
  • 14,811 Thanks
  • 15,499 posts
Posted December 20, 2013 - 11:59 PM
Andy, Welcome to GTtalk. Glad to see you made it here. Have you had you chance to see what happened to the engine?
#3 Alberta Bolens OFFLINE
Alberta Bolens
  • 769 Thanks
  • 349 posts
Posted December 21, 2013 - 12:41 AM
HI.  Let us know what you end up doing.  I have a line on a 317 that does not run.  I'd like to read along see what options are out there..
Merry Christmas!!1
#4 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,771 Thanks
  • 4,263 posts
Posted December 21, 2013 - 02:41 AM
Here you can get some infos for the KT17, maybe they'll help you  Attached File  JD317-KT17.pdf   4.96MB   28 downloads
  • adolmsted said thank you
#5 KennyP ONLINE
  • 38,328 Thanks
  • 45,913 posts
Posted December 21, 2013 - 05:41 AM
Welcome to the forum, Andy! If you need help on the pics, look at the link below!
#6 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted December 21, 2013 - 06:31 AM
Welcome to the forum Andy! Glad you have come on board!
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted December 21, 2013 - 07:29 AM
Welcome Andy. I have a 317 with a series 1. Because the 317 uses a drive shaft and u joints it should be possible to re power with a newer engine. Most people seem to use the Vanguard twins and there are some rebuild kits out there. Pricey though. My series 1 runs pretty good but is a bit noisy at idle. I think some of the cub cadets used the KT17 as well. There is a topic here outlining the differences between Series 1 and 2 engines. http://gardentractor...-and-2-engines/
  • Trav1s and adolmsted have said thanks
#8 jms180 ONLINE
jms180
  • 1,513 Thanks
  • 1,564 posts
Posted December 21, 2013 - 08:06 AM
welcome and thank you for your service. hope you enjoy GTT
#9 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted December 21, 2013 - 11:49 AM
If I was you , I'd try to find a good used Mag 18 or 20 . There almost identical to the KT17's , wont require any tractor modifications to mount , and have a pressurized oil system with filter .
Plus there still a lot of good used Magnums out there .
And cub cadet did use both the KT 17 series I and II and the later Magnum series .
Edit : The magnums use a mag ignition instead of a coil ignition , so the wiring is slightly different .
Edited by Jlaws, December 21, 2013 - 01:06 PM.
#10 adolmsted OFFLINE
adolmsted
  • 5 Thanks
  • 8 posts
Posted December 23, 2013 - 11:27 AM
Thanks for the replies guys!
So first look shows a hole in the right-hand side of case. Inside I can see the rod cap from the right-hand rod laying in the oil.
  • KennyP and jd.rasentrac have said thanks
#11 adolmsted OFFLINE
adolmsted
  • 5 Thanks
  • 8 posts
Posted December 23, 2013 - 11:29 AM
I had wondered about these, since they appear so similar in construction. I'll start looking out for them
#12 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted December 23, 2013 - 11:57 AM
That's nasty. I think that is the fate of a lot of those engines.
#13 adolmsted OFFLINE
adolmsted
  • 5 Thanks
  • 8 posts
Posted January 18, 2014 - 08:51 PM
Ok, So here is where i am with this. I pulled the series I and stripped it down. the case, one piston, one jug, one rod and the crank are toast. Contributing to this was the fact that the Cam is from a series two.
Options
1. KT17
2. KT17 Series II
3. M18
4. M20
5. K series single
6. Onan
7. Repower
Right now I am leaning toward the series II, unless I find a good deal on an M18 or M20
I have a case for a series two, but need a rod, piston, crank and oil pressure relief
#14 Trav1s ONLINE
Trav1s
  • 3,309 Thanks
  • 4,364 posts
Posted January 25, 2014 - 09:14 PM
I would go with the m18/20 or a repower if it were my machine.  Good luck in the hunt.
#15 adolmsted OFFLINE
adolmsted
  • 5 Thanks
  • 8 posts
Posted February 11, 2014 - 06:36 PM
At this point I am going to go ahead with the Series II rebuild. I have been slowly gathering parts while looking for a good magnum. Update to follow soon.
  • olcowhand said thank you
