Lets See Your Wheels Weights
25 replies to this topic
#1 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted December 20, 2013 - 09:15 PM
Lets see those wheel weights and how they are attached.
#2 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted December 20, 2013 - 10:01 PM
33# Sears Wheel Weights, attached with their original hardware from 1968.
  • OldBuzzard said thank you
#3 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted December 20, 2013 - 10:26 PM
20lb front and 50lb rear Bolens weights. Each is attached with two bolts going through the holes in the rims.
#4 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted December 20, 2013 - 10:48 PM
I'm not able to post a pic of my wheel weights from the computer I'm at but here is a link to my thread where I posted pics and descriptions.
http://gardentractor...actor/?p=249640
My weights are made by attaching a torque converter to a break rotor and then attached with four bolts to my rims; 64 lbs./wheel
#5 Talntedmrgreen OFFLINE
  • 3,230 Thanks
  • 2,301 posts
Posted December 21, 2013 - 07:36 AM
Those look a LOT like Simplicity 28# front weights.  Do they have P/N 162097 cast into the reverse side?
#6 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted December 21, 2013 - 07:42 AM
Heres what I use on the 2320. I have a smaller set of brackets that i use on 12"GT wheels.
#7 daytime dave OFFLINE
  • 4,785 Thanks
  • 6,523 posts
Posted December 21, 2013 - 09:03 AM
Lots of rear weight to off set that big blower up front.
#8 KennyP ONLINE
  • 37,502 Thanks
  • 45,509 posts
Posted December 21, 2013 - 09:05 AM
Here's some of mine.
Willie with 35 lb. weights:
Bubba with the 75 lb. weights:
And the Ford with the 75 lb. (total) lead weights I made for it:
  • Moosetales said thank you
#9 MH81 OFFLINE
Posted December 21, 2013 - 10:09 AM
KK's 50# each weights for her Commando 8
And on her tractor
#10 OldBuzzard ONLINE
OldBuzzard
  • 6,984 Thanks
  • 4,783 posts
Posted December 21, 2013 - 10:28 AM
I have two sets of front weights that look like that. One is blank like yours, and the other has BOLENS cast into them.
Then there are a couple of sets of Bolens 12" rear wheel weights. One set is on a G11 and has an 'odd' name cast into them:
When I bought the 1886 Forklift from the original owner, that had been a Bolens dealership, it had some wheel weights in the weight box.
I know that the one on the right is for the Bolens 15" rear wheels. Someone told me, if I remember right, that the one in the center was for a walk behind, and I have no idea what the one of the left is for.  I did get two each of the wheel weights.
I don't know if it counts, but the  forklift's weight box also contained an interesting weight as well.  A section of 55 Gal. drum filled with concrete, and some other unknown "heavy things".
When I bought a Bolens EK7, it had a rear weight on it, but I don't have pics of it. When I was picking the EK7 up, the seller also had a set of really big weights that he had taken off a JD tractor because they weren't "JD branded".  I got them for a REALLY nice price.  Here's a pic of one sitting next to a Bolens 50# rear weight
I think that it was olcowhand that told me that they were for the rear/steering wheels of a combine, and should weigh around 105# each.
They are now on the rear of my plow tractor, the HDT1000, and believe me, they give PLENTY of traction :D :D :D
Now, how does a scrawny old fart like me mount those by himself?
Easy....he uses the aforementioned forklift :D :D :D
#11 MH81 OFFLINE
Posted December 21, 2013 - 10:38 AM
My SS12 has had several sets on it, but I'll just show a couple of versions
2011 PA Plow Day (scrounging for anything I could find)
2013 PA Pow Day (filled tires, 2 sets of Cub weights, one add'l weight inside left wheel)
Current setup (filled tires, 2 sets of Sears weights, one add'l weight left wheel and the old brake rotors inside. Also 40# on the front)
#12 MH81 OFFLINE
Posted December 21, 2013 - 10:55 AM
I only have one pic of the ST16 with the weights on it. The outside ones are extruder endplates and the inside ones are just plate steel. Total of 90# per wheel
Here is Ryan in 2011. I love to dredge this pic up :rolling:
The weight setup works great, we've never messed with it.
Weights are 60# each, plus loaded tires. We put the chain and heavy tools in the left side of his tool box.
  • OldBuzzard and HowardsMF155 have said thanks
#13 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted December 21, 2013 - 10:59 AM
I don't think we need a pic of my butt posted on here, that's all the Bolens G152 needs.
#14 MH81 OFFLINE
Posted December 21, 2013 - 11:02 AM
That's a seat weight, not a wheel weight...
#15 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted December 21, 2013 - 11:06 AM
Being built in Japan, it's still above and beyond what the engineers envisioned when they designed it.
