Cub Cadet 782D Stopped Charging
4 replies to this topic
#1 bigspoon OFFLINE
bigspoon
  • 137 Thanks
  • 99 posts
Posted December 20, 2013 - 08:01 PM
Need to know, how to test an alternator on a Kubota d600. I checked the voltage from the two wires coming out of the Alt. I'm getting around 30vAC full throttle. Measured voltage coming out the rectifier/regulator get only 12.5 vDC. I should be getting around 14-16 VDC coming out reg. Got to battery @ full throttle
#2 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted December 21, 2013 - 07:47 AM
Sounds like the rectifier/regulator may be faulty. However I would check for bad connections from the battery to the engine chassis and at any connectors. Check for a blown fuse. I'd also check the battery voltage when disconnected from the regulator and on a charger to make sure it doesn't have a shorted cell and won't come up past 12.5volts. A bad battery could be the issue.
#3 bigspoon OFFLINE
bigspoon
  • 137 Thanks
  • 99 posts
Posted December 21, 2013 - 08:02 AM
I've put an extra ground wire from battery to engine and then cleaned all other connections Ive check the battery w/o engine running reads 12.5volts. I've also measured volts coming out the rectifier and only read 12.8 volts. I'm leaning toward bad rectifier
#4 olcowhand OFFLINE
  • 43,180 Thanks
  • 32,014 posts
Posted December 21, 2013 - 09:29 AM
Voltage regulator/rectifier MUST have a good ground to work.  If that is good, then likely the regulator is shot.  One off a Kohler or Onan should work just fine, as they use the same AC voltage & 2 stator wires.
  • bigspoon said thank you
#5 bigspoon OFFLINE
bigspoon
  • 137 Thanks
  • 99 posts
Posted December 28, 2013 - 01:10 PM
Finally got some time to T-shoot the non charging issue. Measured voltage A/C out alternator a its above specs @ 27vac checked wiring to reg/rectifier good. Ground good voltage to reg good. Voltage coming out reg bad reading only 12.7vdc. Looks like the reg is bad.
On a side note I did replace the glow plugs and put a 350cca battery in and it does start a whole lot easier, just need to replace the reg so I can charge that mighty little battery lol.
