Kohler Engine Condenser Failure
19 replies to this topic
#16 jabelman OFFLINE
jabelman
  • 2,231 Thanks
  • 1,596 posts
Posted January 25, 2014 - 08:28 PM
Just a very very far fetched idea but maybe check the flywheel magnet?
  • superaben said thank you
#17 MH81 OFFLINE
Posted January 25, 2014 - 11:28 PM
The voltage fluctuations are something I see often with the old contactor style regulator. If not the old black box, I would think you should be closer to 14.
BTW, measure at the battery a d at the reg, it should be similar. If drastically different, bad connection (check reg ground)
Put a voltage dropping resistor in line on the coil and see if that helps (you can also use a resistor coil)
Edit: one other thought. If you disable the charging circuit, does it still kill the condensor?
  • bread320i said thank you
#18 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted January 26, 2014 - 09:38 AM
What am I checking for? I had this engine out earlier and had cleaned the flywheel then.
#19 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted January 26, 2014 - 09:44 AM
I have not tried to disable the charging system. But I will try.
#20 jabelman OFFLINE
jabelman
  • 2,231 Thanks
  • 1,596 posts
Posted January 26, 2014 - 10:34 AM
I just threw it out there as a wild guess just cause you tried all the obvious coil, wiring, etc .. I hear they can go bad and do weird things but its a long shot but you never know if it got bumped or has a crack in it or the poles got flipped.
