D Series Parts Work?
3 replies to this topic
#1 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted December 18, 2013 - 09:53 PM
Have 18 automatic (D series). Has 3/4" front axles. Bought some diff wheels with 1" bearings, was told to be for 200.  Bought one spindle with 1" axle, still need left one.  Thinking the bigger spindle is same as mine, looks like 3/4" part that inserts into axle end.  It gonna work?  Orig posting said for all the D models, but not sure.
  • 14,889 Thanks
  • 15,514 posts
Posted December 18, 2013 - 11:11 PM
WH offered both the 3/4" and 1" spindles on the D-series tractors.
Check with our Sponsors, one of them should have a set to sell..
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted December 19, 2013 - 11:45 AM
Would you have to change the spindles? unless your running a loader the 3/4 should be heavy enough?
Should be able to go to a Bearing Warehouse and buy bearing to fit the wheels with a 3/4" bore?
#4 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted December 22, 2013 - 06:19 AM
It will work if you bore the axle to 1 inch. I have one nos 1 inch and a set of 3/4 ones if needed
