Cub Cadet 129 Problems
3 replies to this topic
#1 zam OFFLINE
zam
  • 62 Thanks
  • 28 posts
Posted December 18, 2013 - 08:47 PM
I don't know if it is just me but my Cub cadet 129 has only two problems i have not fixed and that would be : the steering wheel and shaft came out of the collar at hold i tight . the second being it will start but will not charge we have check every thing from front to back and can't find anything.we hooked up a new s/g and a new voltage regulator. we full fielded it and went to full charge .
#2 IHCubGuy OFFLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted December 18, 2013 - 09:05 PM
If the wheel and shaft came out of the steering column tube I would say it has an issue at the bearing on the bottom.  Probably time to pull the steering box and column out and check to make sure it is all good.
Is the wiring harness new or old?  If its an original harness it could have a broken wire somewhere.  Are all the grounds good and clean?
#3 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted December 18, 2013 - 11:19 PM
Charging system might not be working properly.
#4 zippy1 ONLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted December 19, 2013 - 01:51 AM
Your bearings and retainers are gone if the shaft came up out of the steering box. Time for a rebuild.
You'll need, ball bearing retainer #903-1029, retainer and ball assembly #941-3021, and seal & seal retainer package #394936-R91.And some good grease. And seeing it's apart, now is a good time to true up the cam follower. You don't need to get a new one. What I do is put it in the drill press and take a file and work the groove or notch out of it and clean up the bottom.
Also check the cam assembly to make sure it's not all goobered up. If it is you best hope you can fix it or find a good used one, #703-1085.
Charging could be a number of things, most likely a wiring issue. Check the wires for breaks and grounds to make certain they are making good contacts.
Edited by zippy1, December 19, 2013 - 01:58 AM.
  • Alc and zam have said thanks
