Jac 800 Runs Wothout Head Gasket
4 replies to this topic
#1 VintageIronCollector ONLINE
    Immersed in Tractors
  • 1,426 Thanks
  • 1,857 posts
Posted December 18, 2013 - 06:56 PM
Today I decided to take the head off of my Jacobsen Chief 800. Turns out there wasn't even any head gasket on it but I had it running before I took it off. How would this happen? Also  there was a little bit of oil on the studs that hold down the head. Not sure if the rings are sealing or not. What should I do?
  • bowtiebutler956 and JRJ have said thanks
#2 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted December 18, 2013 - 07:22 PM
 If both the block, and head surfaces are good, and true, they will seal with just the use of some coppercoat, or other sealer. When hot rodding these engines, some folks leave the gasket off to increase compression. I wouldn't do it, but some do. As far as your rings are concerned, was it smoking, or burning oil?
Matt
  • IamSherwood and JRJ have said thanks
#3 VintageIronCollector ONLINE
  • 1,426 Thanks
  • 1,857 posts
Posted December 18, 2013 - 07:25 PM
It smokes a little bit but not noticeable until its revved up.
  • JRJ said thank you
#4 boyscout862 ONLINE
  • 13,431 Thanks
  • 9,380 posts
Posted December 18, 2013 - 07:29 PM
Put a new head gasket on it and put it back together. Give it a good tuning and add Marvel Mystery oil to the gas. Good Luck, Rick
#5 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted December 18, 2013 - 08:28 PM
 The only way to really fix it, is to at least re-ring it, but if your just using it as a worker, you could just keep an eye on the oil level. It just depends what your plans are for it.
Matt
