Hydro Lift Valve Rebuild
7 replies to this topic
#1 MendhamFox OFFLINE
  • 2 Thanks
  • 2 posts
Posted December 16, 2013 - 07:44 AM
I've been helping my dad work on his 73 or 74 jacobsen hydro drive tube frame/open side tractor - it's either a 12hp or 14 hp.  We've had the lift cylinder re-built and also replaced the busted-up cooling fan.  The lift cylinder control valve is leaking and I was wondering if it's possible to rebuild the valve.  I've rebuilt log splitter valves and a JD power steering column - so I have just enough knowledge to be dangerous.  Can these lift cylinder control valves be rebuilt?  If so, do you get a rebuild kit from New Holland or the original valve manufacturer?  For instance, with JD, the power steering rebuild kit came directly from a Parker-Hannifin dealer.
  • 5,418 Thanks
  • 4,703 posts
Posted December 16, 2013 - 08:18 AM
Sorry I can't help with your question other than maybe taking the valve to a hydraulic repair shop for advise.
But I can say, :welcometogttalk:
#3 boyscout862 OFFLINE
  • 13,201 Thanks
  • 9,281 posts
Posted December 16, 2013 - 09:38 AM
Welcome to GTT. Relax and enjoy the site. You can rebuild most valves and cylinders from the old tractors. Our sponsors may have the kits. A local hydraulics shop may have the parts. When purchasing entire assemblies, I've had good luck with https://www.surpluscenter.com/ and www.baileysales.com . While you have it apart, check the hoses carefully. Share some pics of the project. Good Luck, Rick
#4 Bmerf OFFLINE
  • 1,796 Thanks
  • 1,466 posts
Posted December 16, 2013 - 09:40 AM
The valves usually are not very complicated. Most contain a couple of O-rings, a spool valve and a spring or two. Take one piece out at a time and keep them in order. Try not to force anything. Look the spool valve over carefully to ensure there is no wear or defects that will gouge the new O-rings or seals. O-rings can be bought at many auto parts stores or seek out the help of a hydraulic shop. Use plenty of oil to put back together, again don't force anything. It will be very tight with new seals. Good luck. and don't forget :camera:
  • TomLGT195 said thank you
#5 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted December 16, 2013 - 05:34 PM
As stated abovforgot 't force anything at disassembly time and . Be absolute sure that there are no burs!!!! At either end of the spool.
It should slide right out after the spring and cup are removed .
It should have o rings at both ends and nothing in the middle. Good luck and we want pics too.
Oh yeah almost fogot my manners.... Welcome aboard
#6 TomLGT195 OFFLINE
  • 3,924 Thanks
  • 2,848 posts
Posted December 16, 2013 - 06:42 PM
:welcometogttalk: enjoy , Tom
#7 MendhamFox OFFLINE
  • 2 Thanks
  • 2 posts
Posted December 19, 2013 - 07:38 PM
Thanks, all - I will indeed take some photos and post them.  I will also make a list of the after-market seals and o-rings that I end up getting so someone else can replicate the project.
#8 KennyP ONLINE
  • 39,033 Thanks
  • 46,269 posts
Posted December 19, 2013 - 08:03 PM
Welcome to the forum! This is something I haven't done as yet, so I'll be watching for your info!
