I Have A Gravely Hydrostatic 14H Kholer Wont Start
8 replies to this topic
#1 jason ballenger OFFLINE
jason ballenger
  • 1 posts
Posted December 15, 2013 - 09:23 PM
I have a Gravely  Garden Tractor that will not run I want to know if the  ENM hour meter will stop the tractor from starting it makes a clicking sound every few mins.  when key is on run position and dial is not rotating. I have checked all the safety switches, fuses, and fire.
  • 14,792 Thanks
  • 15,492 posts
Posted December 15, 2013 - 09:30 PM
First off Welcome to GTtalk. Does the engine spin over but doesn't fire to start? Do you have 12 Vt at the coil? Have you checked and cleaned the points?
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 15, 2013 - 10:21 PM
Welcome to the forum!
We're talking about the starter motor not spinning, correct?
Have you jumped the solenoid?
Ben W.
#4 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted December 15, 2013 - 10:23 PM
Hello and welcome
#5 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted December 15, 2013 - 11:25 PM
Jason
welcome to the forums
have you a manual for the Kohler?
if not you can download it from the manual section on this site
also check to see if there is a manual for your  Gravely here too
somebody here might here a wiring diagram that might help you
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted December 16, 2013 - 06:17 AM
Welcome! I've never seen an hour meter wired so that it would stop an engine from starting but you never know I guess! What does the plug look like after cranking it. Wet or dry. You could have a fuel problem. The points are another problem area. You say you have fire but is it timed correctly. It's simple to check the gap and condition of the points. The spark should be blue and snappy. The Kohler service manual is a big help if you don't already have it.
#7 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted December 16, 2013 - 07:06 AM
No, the hour meter will not keep the motor from running
#8 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted December 16, 2013 - 07:27 AM
If you provide the model/serial No. it will help some of the guys narrow down the tractor and engine therfor the problem, keep checking back in, great bunch here.
Hr. meter has nothing to do with the running of engine, sounds like it is broke, for the time being, disregard it, depending on the year of the tractor it could be replaced.
Edited by trowel, December 16, 2013 - 07:29 AM.
#9 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted December 16, 2013 - 07:42 AM
What model # Gravely hydro do you have?   Did you get your tractor running?
